Old 02-05-2012, 04:57 PM
monark monark is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
hi again,about the sight gauge. you cant plug the upper end or there will be a vacumproblem.got a flashback an looked it up.we did on a friends old moped once and we hooked the upper end to the breather in the gascap.you gotta have a type of closed loop. ride on
Old 02-05-2012, 06:57 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
Yes,
That makes sense, the air trapped in the sight gauge line would prohibit gas flowing. Could still be done remotely if the line reaches high enough and has a fuel shut off valve at the upper end when the bike was not in use... say if it ran up the seat post and under the seat. Simpler though as you have it.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 03-13-2012, 11:04 AM
waintain waintain is offline
Stop at intersections,when police are present.
Old 03-15-2012, 09:25 PM
bikeman8 bikeman8 is offline
Question Re: Motorized Bicycle Take a Tip...Leave a Tip
hi. im new to mbs.
i ordered my kit saturday and just got it today.
i ordered a mage motors 66cc kit and im not sure if this is the right one but it has a slant head.
in the assembly video it had a completley different kit.
im having trouble with the wires. i hooked it up like it said to
but the kill switch wont work.
the kill sitch is yellow/red and green
the engine is green black and white
and the plug cap box is green and black.
i have all the green together.
and both black with red/yellow wire.
the white one is supposedly for headlight?
i have it on a 26 inch huffy cranbrook.
and also, i accidently broke 2 spokes and bent a few due to a misalignment error
can i still ride this safely?
any help would be apreciated. thanks
Old 03-15-2012, 10:57 PM
GearNut's Avatar
GearNut GearNut is offline
Hi bikeman8, welcome to the forum!
The correct wiring for your setup would be:
Green to Green (the way you have it all ready).
Black to Black.
Leave the kill switch disconnected until after you have the engine running.
The kill switches are well known to be shorted out brand new. If yours is too and you connect it right away, the engine will never run, and you will be mad at it.
You can easily stop the engine by applying the choke or by holding the rear brake on and quickly letting the clutch out with the engine at idle speed.
When you do get to connecting the kill switch it does not matter what wire goes to what so as an example: Green to Green wires and Yellow/ Red to Black wires.
The white wire is supposed to be used for powering a light but it is too weak to power any light that will actually be bright enough to be any good.
Either cap it off with electrical tape or heat shrink tubing, or best to just cut it off right at the magneto inside the magneto housing.
Broken or bent spokes should never ever be trusted for any reason EVER.
Either repair the wheel or replace it.
It is not worth injuring yourself over.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 03-15-2012, 11:03 PM
The_Aleman's Avatar
The_Aleman The_Aleman is offline
<removed out of protest to certain "staff" practices in this forum.>
Meh.
Old 03-15-2012, 11:44 PM
Jumpa's Avatar
Jumpa Jumpa is offline
and a fool proof alignment adapter for rear sprocket
scroll 3/4 of the way down under bike parts you will
see an aluminum sprocket adapter sent by the gods
It puts the load on the hub ,where it should be, not \
on the spokes
http://www.sportsmanflyer.com/
Old 03-15-2012, 11:45 PM
thanks for the help guys.
also, im having trouble aligning the wheels.
if i brought it up to a motorcycle shop could they fix it and tune it?
ill try and post pics of my bike that ive dubbed frankenstien, as i have had to make the front mount from scratch.
Old 03-15-2012, 11:51 PM
Jumpa's Avatar
I had the exact bike the Cranebrook it is blue pic in my profile photo's you can see in my picture how high it was mounted "the motor" before I got rid of that stupid pull starter that almost ripped my arm off . When I got rid of the pull starter I was able to drop the motor down to where it belonged made life so much easier & bike more balanced
Old 03-15-2012, 11:56 PM
Jumpa's Avatar
curious as to why you had to make the front mount from scratch? No need unless you got the pull starter!
Tags
MotorBicycling.com
