Old 10-10-2011, 10:43 PM
vincent713 vincent713 is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Originally Posted by Large Filipino View Post
Another tip. If your clutch cable snaps,disconnect your rear brake cable and use that. It will get you home on just the front brake.
Isn't there a fix a flat can for bicycle like they have for automobiles?
Old 10-11-2011, 12:38 PM
corgi1's Avatar
corgi1 corgi1 is offline
interesting fix ,how does it attatch to the clutch-cable and arm
and yes, It's as bad as you think and they are out to get you.
Political Correctness:
A doctrine fostered by a delusional, illogical liberal minority, and rapidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Old 10-11-2011, 07:44 PM
ScreamingCruiser ScreamingCruiser is offline
I'm not sure but check out your local wal-mart , they have something called slime. It's either a product before or after a flat.
Old 10-11-2011, 07:47 PM
Check out wal-mart for something called slime. It is a before or after a flat product I think. I was on the run when I saw it. Didn't have much time to really check it out,sorry.
Old 10-11-2011, 07:56 PM
DuctTapedGoat's Avatar
DuctTapedGoat DuctTapedGoat is offline
There is a fix a flat equivalent for bicycles. Though, it takes just under two cans to get to the PSI I like in my aired tires.
http://unixfi.co/uk/MotorizedBicycle/48ccEdition.html
Old 10-11-2011, 10:07 PM
Where can I find those fix a flat for bicycles? The ones at Walmart "slime" are for before you ride to prevent from having a flat. I want one that can fix a flat when I'm 10 miles away from home. I have a fear of getting a flat tire out on the road more than having engine issues. I can at least pedal home if it's an engine problem. I'm stuck like chuck with a flat tire.
Old 10-11-2011, 11:37 PM
Originally Posted by JTinFL View Post
I use 1" wide under ground rubber electrical splicing tape for rim.Streching it while wrapping 3 times.It will conform to rim and virtually become a solid piece of rubber.
What is the purpose of this?
Old 10-11-2011, 11:50 PM
GearNut's Avatar
GearNut GearNut is offline
To prevent the spoke nipples from puncturing the innertube.
The_Aleman:
________________________
ROTFLMAO!!!!!!
Old 10-12-2011, 10:05 PM
CTripps's Avatar
CTripps CTripps is offline
I had to get rid of the pool of leftover slime that was in my tire from the other day. Not wanting to get it all over things, dump it in with the garbage or just pour it away (where I live the environment police would be on me in a heartbeat), I carefully poured it out into a half-jar of (clean) clumping cat litter. It worked like a charm, no liquid made it to the bottom of the jar, and there's a nice little lump in there. The same thing worked with catching a bit of gas out of the line when I went to change fuel lines, too.
CT
Any day that starts with a good ride is already a better day, and a bad day riding still beats a good day working.
My Builds: My Beast, Harley59's bike, my Cruiser
Old 10-14-2011, 03:35 AM
Walmart - it looks like a can of fixaflat, but as big as a little Red Bull drink.
Ultra Bike Tire Sealer and Inflater 4.96
Tags
MotorBicycling.com
