Old 09-11-2009, 03:03 PM
pedro granero pedro granero is offline
Default Respuesta: take a tip...leave a tip
Me presento y saluldo a los foritas
Pedro Granero
Old 09-11-2009, 03:13 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Default re: Motorized Bicycle Take a Tip...Leave a Tip
I agree with Pedro 100% i think.HD
You never know what you might know,you know
Old 09-12-2009, 06:55 PM
Revo Revo is offline
I did'nt read ALL the tips, but I'm leaving one and it might already be in here but I did'nt see it. When u need to replace your spark plug boot go get a coil wire from napa for 4.00 buck cut it in half and u will have two new plug wires.
Old 09-23-2009, 04:05 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
put nickels inside your grips. not only does it keep the bar end from cutting through it, but it increases the value of your bike!
Old 09-23-2009, 04:41 PM
silverbear's Avatar
silverbear silverbear is offline
The Boy Who Never Grew Up
That's a great idea! How much more would my bike be worth, do you think?
Silverbear
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
Old 09-23-2009, 04:48 PM
bairdco's Avatar
you just have to add in ten cents to the price when you sell your bike.
Old 09-23-2009, 04:53 PM
Venice Motor Bikes's Avatar
That's a old skool BMX trick right there!!!
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 09-24-2009, 09:23 PM
MikeJ's Avatar
MikeJ MikeJ is offline
I run with a jackshaft kit from Sick Bike Parts on a frame with no fenders. I recently realized that I can jam a length of cardboard box corner, 2 inches x 2 inches x 15 inches, into the frame, separating the exposed jackshaft, sprockets, and chains from the 26 inch tire and flying road debris.
The cardboard is rigid enough to hold itself into place, but can be bent at the corners to jam itself at the bottom bracket and into the rear wheel down arms. The cardboard is also kind of easy to cut into custom wider shape at the area between the jackshaft and wheel. Unless the cardboard gets water-soaked, it should last a long time and keep the moving parts cleaner. It clears the tire by a quarter inch or so. It rubs against the jackshaft a little, but a bit of axle grease at that location makes the contact a non-issue.
Spray paint it with matching (or contrasting) color and it looks like a factory add-on. Spray on the inside angle and make it water proof. If necessary, it is easy to remove and replace, maybe with different paint; maybe some ownership indentification.
MikeJ
Old 09-24-2009, 09:27 PM
mechanickid's Avatar
mechanickid mechanickid is offline
MikeJ
i did the same thing with a left over piece of vinyl siding i cut to fit, very light and self supportive.
its only too fast if you cant stay on!
Old 09-28-2009, 08:44 PM
Earthman's Avatar
Earthman Earthman is offline
Default Easy & cheap way to mount a flashlight.
Here's an easy and cheap way to mount a flashlight to the handlebars of your MB. Use two tangential screw clamps (that's the technical name, but you may call them worm gear clamps, or hose clamps) as shown in the attached photos. The flashlight is clamped securely, but there's enough "flex" to adjust the beam to where you need it. The cost is only a few dollars.
Tags
MotorBicycling.com
