Old 08-11-2009, 11:13 PM
cyclepro101's Avatar
cyclepro101 cyclepro101 is offline
Default re: Motorized Bicycle Take a Tip...Leave a Tip
Not sure where I got this tip from but it is a great way to lube the chain.
What I do is mix in a small bottle 50% WD-40 and 50% Graphite powder. It goes on real easy and ends up being a dry lube. Works a treat and no mess.
Old 08-12-2009, 03:57 AM
BarelyAWake's Avatar
Originally Posted by DOC BOLM View Post
Place a small magnet inside the finger of a rubber glove,you can place nuts or bolts in some tight places.Sears sells a pair of magnet gloves for 25 bucks,make your own for nothing.HARLEYS DAD
damn yer eyes... I coulda used this tip years ago, don't I feel foolish for not thinkin of this
Thanks man!
Old 08-16-2009, 09:00 PM
kla63's Avatar
kla63 kla63 is offline
Question Re: take a tip...leave a tip...or a bunch of 'em
Originally Posted by Bikeguy Joe View Post
These engines were originally made to haul around people for a tiny sip of fuel, low operating costs, and ease of MAINTENANCE....kinda like the old V-Dub beetle. Or the early Honda step through. Or the model T.
Top performance for these engines then should be defined as great fuel mileage, ease of operation and low overall cost.
Some are treating these engines like they should do something other than putt around on a litre of fuel all day and get you where you are going with a minimum of drama.
You aren't going to make one of these engines haul you down the coast @ 40+ MPH or win any stop light drags with that blue haired lady in the Volvo. (although, you may)
You aren't going to find any magic fuel or "performance" add-on that is going to do anything you can't do for pretty much free with the exception being your time. Coleman fuel? nah...super duper spark plug thingy? nah....NOS or turbos? Are you serious? You aren't really serious, are you?
100+ MPG? Yes. Easy running, and easy maintenance? Yes. Lots of tinkering and learning to do maintenence and repairs? Yes, if you want to keep riding it. Fun? Of course, why else would you want to own one?
Buy a good plug, and a good replacement sparkplug wire cap from Pep Boys or other favorite large auto outlet.
Never remove a sparkplug from a hot engine, you may remove the threads from the head as well.
Here's a list of replacement plugs- do it today!
NGK B5HS (preferred)
Champion L86C
Champion CJ7Y low profile or CJ-8
Autolite 4093 or 425
Mix your fuel/oil mixture @ 20:1 for break-in and 36:1 after.
Buy some good gasket paper DON'T MAKE ONE FROM A CEREAL BOx! (really cheap) and make a couple intake gaskets, and install one, even if you think yours is fine. You can make gaskets really easily by drawing the new gasket by using the old gasket as a pattern, and no, it doesn't have to be PERFECT. Use an exacto knife and take your time, finish the rough stuff with some 220 sandpaper. Some of you (me) old-timers will use the "good old ball peen hammer method" to make the gaskets.
Make sure your carb is set right and that means check where the needle clip is, start at the second from the bottom in most cases. One slot lower near sea level. I have two bikes and they are both set up diferently due to poor tolerances in manufacturing FIND THE ONE THAT WORKS FOR YOU- it just depends on your carb and your elevation. (I'm @ 1000' here)
Clean out your tank before you mount it...at least look in there and see if it's full of rust or crud. You can use a shop vac ONLY IF THERE HAS NEVER BEEN ONE DROP OF FUEL...otherwise you'll blow your shop vac to smithereens.
While your in a cleaning mood, pop off the mag side cover and clean all the metal shavings out of there with some spray can brake cleaner and compressed air. Check the area around the sprocket too- full of metal dust!
To save yourself a lot of hassle, buy a length of M6X1.00 pitch threaded rod and REPLACE ALL THE STUDS. Or make them outta bolts like I did. Those would be the intake, exhaust and also the four mounting studs. The originals are made of "anti-metal" and will strip at the first inopportune moment.
Secure all wires with zip ties or electricians tape so none are pulling at the ends or connections. Seal up any ends/connections that are in doubt with liquid electricians tape...READ THE DIRECTIONS ON THE CAN!
Grease your gears with some wheel bearing grease or lithium grease before you ever fire the engine up, then again after about 50 miles. USE ONLY A TINY AMOUNT OR YOU'LL BE CLEANING THE CLUTCH SOON. (a dab about the size of a pencil eraser is PLENTY. Clean them first with some brake cleaner, or carb cleaner, then lube.
Don't spray brake or carb cleaner in your eyes, you won't be doing anything else on the bike for awhile afterwards, if ever.
While you are greasing stuff remove, clean and grease all your wheel bearings, or YOU WILL BE SORRY. Bicycles are not really made to haul a 200+ pound guy over the road and all the bumps/potholes/ect @ 25-35 mph. The bearings take a massive beating. Use red grease because it starts to turn black when it needs servicing.
Make sure your chain is aligned and lubed. Same goes for the pulley/tensioner. Don't make the chain TOO TIGHT. 3/4-1" play.
Always clip on your masterlink so the opened end faces toward the rear when it's at the top of the chain run and going forward.
Zip tie your spokes where they cross while you are installing your sprocket.
Balance your wheels- I used solder wrapped around the spokes at the rim. You can buy stick on weights at the sporting goods store...in the golf aisle.
Don't try to use your clutch to take off.
Use loctite on every bolt you put a wrench on, and don't OVERTIGHTEN the head bolts, or any bolt that goes into aluminum. 15-20 ft/lbs. is enough, and that goes for the spark plug too! While we're on the subject, you do use anti-seize compound on the plug threads, don't you? Never remove a sparkplug from a hot engine, you may remove the threads from the head as well.
Make sure your brakes are up to par. Stuff hurts more @ 35MPH than it does @ 10MPH, especially if it stops you before your brakes do.
Ride defensively, because the only drivers that will see you are the ones you DON'T want to see you- aka "da fuzz".
If you have a problem with dogs chasing you- eventually they get old and bored and leave you alone...if they are smart.
what do you set your spark plug gap at ???
Old 08-20-2009, 03:45 PM
RaleighRider RaleighRider is offline
When I first put my kit on my raleigh, the chain tensioner would not stay put. Nomatter how tight I made it, it would be fine for a few minutes, then the chain would pull it, causing it to rotate into the spokes. It only rotated and did not slide.
Problem: Tensioner falls into the spokes under strain.
Solution: Simple-Drill a hole through the tensioner mount and the piece of frame where it is clamped on. Put a bolt through the hole and secure it with a nut. This makes it impossible for it to rotate.
I have had no problems since doing this.
Old 08-20-2009, 04:00 PM
I have a big old magnet I found somewhere a long time ago about the size of a TV remote. If I need to get a screw in somewhere tight I rub my screwdriver on it for a few seconds to magnetize it. When I want to demagnetize I just whack the screwdriver on something hard a few times and that does it. Makes life a lot easier for me, just be careful what you magnetize...
Old 08-20-2009, 08:03 PM
yodabob yodabob is offline
Not to put a weak point in your wheel stay tube by putting a hole in it, might I recommend that the next time you take the outer half of the tensioner bracket at just below center line of your frame tube and drill and tap it 1/4-20 and put a set screw in it and torque that against the tube after tensioner is tight.
Yodabob legal in PA
YouTube - motorized bike street legal in PA
Old 08-21-2009, 06:30 AM
Default Re: take a tip...leave a tip...or a bunch of 'em
.020"- .025"
Old 08-21-2009, 02:01 PM
I just clocked 850 trouble free miles running an Autolite #275 plug gaped at .030
Please see attached pic of how clean it is burning.
Yodabob legal in PA
Old 08-26-2009, 05:43 AM
myocardia myocardia is offline
Originally Posted by MikeJ View Post
I may look goofy when riding, but a real helmet and high-visibility jacket states I am serious about getting home at the end of my ride. Now if we could only better avoid the cagers intent on ruining our day....
My tip is to shoot at the first two or three that get close, and the rest of them will give you all the room you need.
Robert
The best solar, wind, EV, and alt energy forum on Earth
This space under construction, which may be why I'm half a bubble off plumb.
Old 08-30-2009, 04:54 PM
fakeplay's Avatar
fakeplay fakeplay is offline
Originally Posted by deacon View Post
You know most of us do things eventually to modify the bikes for the better or worse. It would be a nice gesture if we stick them out there for others to see.
Take this one for what it is worth.
The clutch lever in my kit was trash from the first. I never could make it work worth a darn, so I replaced it with a brake lever I had laying about. Here is the trick. I cut a piece of old inner tube to lock the handle up so I could roll the bike in and out. I leave it on the grip so I can use it to hold the clutch in if I need to adjust the bike.
I also hated the throttle that came with the bike. I replace it with a shifter from a mountain bike. I can lock the throttle in any position while I work on things. I don't think either of those is earth shattering, but they seem to work better for me. Probably won't help anyone else.
So leave me your tip I can use all the help I can get...
If your kit doesn't work sa advertized my tip is to send it back until you get one that works properl. The ell with micky mousing everything.
Tags
MotorBicycling.com
