Old 05-13-2009, 05:28 PM
bravofire84's Avatar
bravofire84 bravofire84 is offline
Cool Sproktetus queastionus
i some how over the winter lost my rear sproket in mid build so what i wanna do is use a front sproket on a regular10speed that has 51 teeth does anyone think this will work let me know. <stuck in ohio>
Old 05-13-2009, 06:59 PM
Large Filipino Large Filipino is offline
Default re: Motorized Bicycle Take a Tip...Leave a Tip
As long as you have the holes drilled rather perfectly aligned to make installation go easier. I assume you have the other hardware sans sprocket?
Old 05-13-2009, 09:54 PM
mechanickid's Avatar
mechanickid mechanickid is offline
i would recommend the middle front sprocket, which is usually 38 teeth. you will have to grind the center about 1/4'' larger to fit it over the hub, and most likely drill holes for the bolts. i've done this myself, it was a lot of work. i was trying to make a derailleur assembley so i could change gears without a jackshaft, but it was way too hard to make the chain move right. if anyone tries it you need to convert to regular bike chain first. (if your trying to make a derailleur on the left side of the wheel, the chain works fine for single speed)
its only too fast if you cant stay on!
Old 05-18-2009, 12:24 AM
mc1320 mc1320 is offline
Try sparying undercoating on the inside of side covers cuts down on noise
Old 06-13-2009, 09:35 AM
roxrcool roxrcool is offline
simple spark plug wire upgrade. i was cruising the junkyard with a buddy looking for some vw parts, when I saw an ignition coil wire just sitting on the ground, at perfect length. turns out they are all over the place. when I went back up front, I asked the guy if he wanted a few bucks for it, when he told me I could have all the spark plug wires I could fit in my pocket. cut the other end off, screwed it on, and my bike runs 10 times better now.
Old 06-13-2009, 06:38 PM
yodabob yodabob is offline
I also found the spark wire from an industrial gas fired heater works great.
Yodabob legal in PA
YouTube - motorized bike street legal in PA
Old 06-13-2009, 08:45 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Place a small magnet inside the finger of a rubber glove,you can place nuts or bolts in some tight places.Sears sells a pair of magnet gloves for 25 bucks,make your own for nothing.HARLEYS DAD
You never know what you might know,you know
Old 06-13-2009, 08:50 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
A bit of newspaper inside a socket holds nuts in till you get them started, then it pulls right out when they are tight...
Old 06-18-2009, 02:18 AM
markeatmark's Avatar
markeatmark markeatmark is offline
One good tip if you have a front fender. get rid of it so you dont eat the blacktop. My front fender broke loose and I went over the handle bars in a split second. did a belly flop at 20mph. and it hert. and i have road rash on my elbows and chest. so a good tip lose the front fender.
Old 06-19-2009, 06:40 PM
deacon's Avatar
they have been preaching dump the finder or reinforce it since day one on this site..... I never had a front fender on the junk I built.
Tags
MotorBicycling.com
