Old 06-04-2016, 09:14 PM
curtisfox curtisfox is online now
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
Anyone filing aluminum, coat the file with candle wax firs and the bits won't stick, and clog the file..........Curt
Old 07-07-2016, 12:22 PM
Chinaboi Chinaboi is offline
So I'm having trouble with a China girl 48cc motor that when the clutch is realeast and the bike is idling the drive train won't engauge
Old 07-07-2016, 12:30 PM
crassius crassius is offline
this should be in troubleshooting section, but you should open both covers and see where movement stops
Sometimes I sets and thinks, sometimes I jes sets.
Old 07-07-2016, 12:32 PM
Thank you so very much!
Old 07-07-2016, 04:37 PM
Robbie's Avatar
Robbie Robbie is offline
Hi you probably need to adjust your clutch.
Take off the right side cover and tighten up the flower nut
Old 07-07-2016, 05:00 PM
Thank you will do as I'm hunting to see where the movement stops! 😂
Old 07-08-2016, 05:31 AM
rager.eric@yahoo.com rager.eric@yahoo.com is offline
either clutch too tight! loosen clutch nut(. not tighten, or internal problem?
main drive broke. probably the clutch, they are extremly sensitive on the "girl"
Old 09-15-2016, 02:06 PM
so after a few hours of reading through the forums im curious if the clutch shaft is the same size for the 48cc and the 66cc need to adjust the spring a little or just swap them out while im rebuilding the 48cc?
Old 09-15-2016, 05:33 PM
mogollonmonster's Avatar
mogollonmonster mogollonmonster is offline
If I'm not mistaken the whole bottom ends are identical. And I must dispute the above claim that the ChinaGirl clutches are sensitive. They are finicky, and can be difficult to adjust, but once you get it tuned in, hammer on that sucker for a few thousand miles, you'll kill the rings or something else long before the clutch, IME. I'll leave a real tip another time.
Old 09-15-2016, 06:18 PM
woodruff keys are usually different - swap all as a unit
Tags
MotorBicycling.com
