Old 04-02-2016, 08:53 PM
hazzardous1 hazzardous1 is offline
Default Re: Motorized Bicycle Take a Tip...Leave a Tip
oops caps!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-03-2016, 10:43 AM
crassius crassius is offline
sticking clutch arm usually means it is being pulled past its flat spot
Sometimes I sets and thinks, sometimes I jes sets.
Old 04-03-2016, 07:11 PM
yea looks like theirs some wear their any ideas on where to begin on fixing?
Old 04-03-2016, 07:21 PM
wear usually means that it wasn't greased often enough and/or the cable & clutch adjustment didn't leave that arm free when lever was released
grease it well & be sure there is free play after adjusting and it will last a while, but new ones are fairly cheap
Old 04-03-2016, 09:37 PM
Jonda500 Jonda500 is offline
My latest engine came with the clutch arm incorrectly orientated on the spline - once I managed to get it off it was easy to reorientate it slightly inwards of pointing directly straight back (with the cable back on and the slack adjusted out). The way it was (pointing out diagonally between straight back and straight out to the left) it was sticky and extremely stiff.
John
Old 04-04-2016, 09:11 AM
yea this one was similar except it had the set screw that held the arm in place broken off ( easy fix got lucky enough for it to have left threads for a new one) but the clutch finnaly gave out when riding in to work got cut off buy a lady and almost t -boned her hit and rode the clutch while yelling about her not seeing me so will do with the grease till payday then gonna try to get it fixed if not just order a new motor for the newest build and keep this one to tinker with thanx for the advise on everything.
Old 04-14-2016, 02:01 PM
so does anyone have a item number for the bumper bar bearing or the steel shot looking thing behind the bumper bar? like at ace hardware or something i have managed to wear a flat spot on mine and need to replace it.
Old 04-14-2016, 07:26 PM
8mm if you can find it, but 5/16 in is OK & easier to find
Old 04-16-2016, 02:21 PM
so does anyone know the hub diameter for the huffy cranbrook beach cruiser in going to get one of the hub attachments for the sprocket and chain drive and would verry much like to get the right one
Old 04-30-2016, 02:39 PM
so i recently got a pair of the motorized rims from gasbike.net (hy-27) has anyone used these? and if so lol what tire size should i get for them and do they make the tires in a solid (no flat ) also im kinda curious about the rim width i have a huffy cranbrook that works great with the little 48cc motor kit just curious if i should go ahead with the tire shrinking if you will considering the rim is literally half the width of the stock rim get back to me if you guys have any suggestions on this
Tags
MotorBicycling.com
