Old 10-11-2009, 12:52 AM
MaxPower's Avatar
MaxPower MaxPower is offline
Default freewheel adapter for square taper spindle
I'm doing a project with a tandem bike and want to use the rear riders bottom bracket as a jackshaft. I'm having problems finding a dual sprocket. I need a freewheel adapter for a square taper spindle that can accommodate two freewheels. I've attached a picture of what I'm thinking.
Also, If it use a Keyed shaft with a two freewheel adapters, how would I adapt the shaft to the bikes bottom bracket. Do they make bearings that can thread into the bottom bracket?
Name:	freewheel adaptor.jpg
Old 10-11-2009, 01:49 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
Default Re: freewheel adapter for square taper spindle
i dunno about the freewheel adapter, but you can get a three piece crank bottom bracket adapter (american to european conversion, technically) from bikepartsusa.com for $17.58...Pyramid 3 pc, Bottom Bracket Conversion Kit | BikepartsUSA
i know they make sealed bearing set ups, too, and there's a kit that has two aluminum pieces that bolt in to your frame so you can run any euro bottom bracket you want, but those are more spend-y.
hope this helps.
Old 10-11-2009, 02:14 AM
MaxPower's Avatar
yeah... not much help. I was thinking that I could find a bolt that fits freewheel threads and then find someway to cut the square taper into the bolt. Does anyone know if a bolt like this exist or if a mechanist can cut a square taper into a bolt? I was also thinking of starting with a tapered crank and cutting the crank off and treading it. What is the thread size of a freewheel? how would I describe it to someone I wanted to buy it from?
Old 10-11-2009, 04:28 AM
Blakenstein's Avatar
Blakenstein Blakenstein is offline
Spindle??????????????? what ,......for your disk brake?????hahahahahahahahahahahahahahahahahahahaha hahahahlololololololololololololololololol you better get your spider gears working firsthahahahahahahahahahahahahahahahahahahahahahah lololololololo:
Old 10-11-2009, 04:31 AM
Im havin prblems with my crown and pinion.. maybe you could help hahahahahahahahahahahahahahahahahahahlolololololol ololoolololololol
Old 10-11-2009, 06:43 PM
MaxPower's Avatar
I don't understand whats funny. please enlighten me.
Old 10-12-2009, 05:04 PM
Junster's Avatar
Junster Junster is offline
SBP sells a set of cranks, hvy duty freewheel, duel sprocket setup for their shift kit. It would be only on the right side. If you used a shift kit and a extra set of cranks, fw, sprockets for the rear pedals you could get it to work.
Put something FUN between your legs..
Old 10-12-2009, 05:23 PM
MaxPower's Avatar
here is a better picture of what I'm trying to do
Old 10-12-2009, 05:49 PM
Junster's Avatar
Will there be pedals on the rear bottom bracket?
Old 10-12-2009, 05:51 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
Max Power, Interesting!! You Do Have A Bit Of A Challenge. If There Is A Way To Use Sealed Bearings In The Bottom Bracket Housing And A Keyed Shaft With Staton Free Wheel Adapters. Bearings With Outer Snap Rings. Then You May Need A Wider, Longer Front Pedal Spindle To Line Up With Back Sprockets. When You Go To A Machinist, It Gets Expensive In A Hurry. Where Is Your Girl Friend Going To Put Her Feet?? Or Will It Be A Cargo Bike? Good Luck. We Will Be Watching You!! Lol. Ron .
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
