Old 10-10-2009, 05:39 PM
Prettyboy Prettyboy is offline
Default Thottle cable to carb trouble
My throttle cable was working perfectly until I stupidly unscrewed the top of the carb and I guess I messed it up. I put together like I think it's supposed to go
This Pin
DSCF0884 on Flickr - Photo Sharing!
Then this silver spacer thing on top
DSCF0882 on Flickr - Photo Sharing!
Then in
DSCF0879 on Flickr - Photo Sharing!
I threaded the wire through the spring, put it in the cylinder piece then put the end of the cable through the little opening
DSCF0877 on Flickr - Photo Sharing!
carbpict004 on Flickr - Photo Sharing!
But when I pull the throttle it just pulls up and doesn't pull back
DSCF0872 on Flickr - Photo Sharing!
If someone could help me and rid me of further frustration that would be great.
Old 10-10-2009, 06:22 PM
Hot Wheels's Avatar
Hot Wheels Hot Wheels is offline
Default Re: Thottle cable to carb trouble
HI,EVERYTHING LOOKS GOOD. THE ONLY THING I CAN THINK OF IS MAKE SURE THE SPRING IT'S SITTING FLAT IT IN THE CYLINDER AND NOT CAUGHT UP ON THE CABLE, THAT HAPPENED TO ME WHEN I HAD THE SAME PROBLEM. IF IT IS SEATED RIGHT CHECK AT THE THROTTLE TO SEE IF THE CABLE END IS STILL IN THE HOLE. HOPE YOUR RUNNING SOON !
Old 10-10-2009, 06:50 PM
The spring is flat but I just don't see what pulls up the pin because theres nothing pulling on the silver spacer thing. It's just stuck in the little area where the cable head seems it should be.
Old 10-10-2009, 07:01 PM
Hot Wheels's Avatar
the cable end should be caught under the barrel. the silver spacer is there to hold the needle valve down and the spring holds down the silver spacer.
Old 10-10-2009, 07:56 PM
Yes ok but doesn't something get pulled and released that compresses the spring. The throttle cable just pulls and doens't return I feel like I'm missing a part because I have it together and it still doens't work.
Old 10-11-2009, 12:36 PM
I think I realized my problem
This silver cylinder thing
is supposed to move up
and down?
DSCF0875 on Flickr - Photo Sharing!
But I don't think mine does or maybe it isn't just lubed up enough?
Old 10-11-2009, 01:26 PM
bseelbach bseelbach is offline
Your pictures won't load but I suspect you have the order correct. Throttle end through the cap, through the spring then through the slot on C clip and E clip (on pin) then through carb slide.
I suspect that your problem is orientation of carb slide. Make sure the slot in the carb slide is aligned with the pin inside the carb. Assemble it wrong and it will technically go together but not work properly. Carb slide will be locked up resulting in WOT and no throttle return.
Old 10-11-2009, 06:17 PM
Bikeguy Joe's Avatar
Also, I have had to sand down a few slides that were just too tight.
Old 10-11-2009, 07:18 PM
Yeah I think I did it right but I gotta find some lube for it and it was workig fine before so I don't think it's too tight but I could be wrong.
Old 10-13-2009, 04:25 AM
Junster's Avatar
Junster Junster is offline
There is a pin inside the carb neck. There is a slot down the side of the carb slide. When you put the slide in the carb the slot has to line up with the pin. Put the slide in the carb and rotate the slide till you feel it drop down over the pin. Look thru the carb to make sure the slide is all the way down closeing the carb throat before you screw the top on.
Put something FUN between your legs..
