10-08-2009, 11:38 PM
Best way to bend chain tensioner?
So I have been reading around and I read how people have bent their chain tensioner thingy so that it aligns with their chain. I'm just wondering what's the best way to bend this a couple degrees? Mind you i'm not in a shop and I have reagular tools. No special heating, or anything haha.
10-08-2009, 11:59 PM
a guy who makes cool bikes
Re: Best way to bend chain tensioner?
i think the most popular way to bend a chain tensioner is to get it caught in your spokes...
sorry, i've had a few beers.
here's a serious answer;
put it on your bike where it would go if it was inline with your motor and wheel, then take a crescent wrench and bend it slowly in the direction you need to go.
10-09-2009, 12:45 AM
I gotta admit I laughed at your first "suggestion"
Ok so just srew it on almost or all the way tight, then bend it?
I'm just afraid something is gonna snap.. and knowing my luck with this engine kit and everything, i'll find a way to snap it..
By the way, I got my kit in the mail last thurs so it's been a week since i've been trying to put it together and just wanting to ride the dang thing.
I'm just getting really sad... because this shouldn't be that hard...
10-09-2009, 02:03 AM
Put it on and ride it to a neighbor with a torch. If you need to bend right away, take it off and put it in a vise or support and use a soldering torch from the hardware store to heat it. Its thin enough where the heat from propane will help bend it. Just make a line where the bend will be and only apply the heat on that line. Then bend it in a vise using the cresent wrench. I bent something like it with a C-clamp on each end. Let it cool on its own,no water...
10-09-2009, 07:24 AM
We doe neeeeeed no STEEEEENKIN' tensioner.....
10-09-2009, 07:38 AM
I use a vise and a big pipe wrench.
If you don't have the tools, try a high school shop, vo-ed school, or even a local mower shop. If they aren't busy, or you call ahead, it's usually free.
10-09-2009, 07:39 AM
BTW- they are soft metal, and heat is not really needed. They bend easily.
10-09-2009, 12:35 PM
I just used the Channel Locks I always carry on me to bend mine when I still had one. Crescent wrench would have required less grip strength though. It's just mild steel so you don't have to heat anything and you don't have to bend it very much anyway.
10-09-2009, 01:04 PM
And keep in mind the key word here is 'twist'. The chain stays on most bikes are not parallel with the chain path. The stock tensioner, when bolted to the chain stay (frame) will position the tensioner wheel at a slight angle to the chain. That is the angle you want to remove. Viewed from the rear of the bike it is easy to see how much 'twist' the bracket needs to align the wheel with the chain. Depending on the bike quality, I'd be careful trying to twist the bracket with it attached to the bike. A bench vise is the preferred method but not a tool everyone has. If you have to bend it on the bike, go slow and make sure the bracket is bending, and not your frame. Heat is not necessary.
10-09-2009, 07:01 PM
Ok so i managed to twist my tension'er so that it's as straight as I can get it with my rear sprocket. I was so excited and tried to start my engine again... but about 7 good pedals down my driveway, the DAMN CHAIN SNAPPED OFF AGAIN!! AHH WHAT IS WRONG?@?@ I've tried a tight chain tension, and i've tried a loose chain tension. I just don't get this...
Do you suppose I could make a video of what's going on with me and then I could put it on my youtube and link you guys to it? Maybe i'm not noticing something here that you guys might pick up...
Should I do ahead and make a video??
| Thread Tools |
| Display Modes |
Linear Mode
