Old 10-06-2009, 10:20 PM
Deadend's Avatar
Deadend Deadend is offline
Default Longer drive chains?
Im just about done ( finally! ) with my first build ever but the drive chain is too small.
Suggestions? I've done the "search" and most recommend a tractor supply shop - problem is there isnt one for about 60miles.
Is there a chain offered by any vendors here that would match the 80cc china kit drive chain ? Thanks in advance
Old 10-06-2009, 10:54 PM
2door's Avatar
2door 2door is offline
Default Re: Longer drive chains?
Have you tried Ace Hardware or a Grainger Supply? They carry #41 chain which is a good replacement for the kit supplied #415 chain. It is usually a better quality too. If you're set on using the kit style chain most of the vendors/sponsors here will have it. You'll be ahead if you also purchase a good quality chain breaker, or if you do like many, just grind off the pins and punch them out. To shorten a roller chain you'll need to remove two links to use a standard master link or one link if you use what is called an offset link. Hope this helps get you on the road.
Old 10-07-2009, 07:42 AM
Deadend's Avatar
hey there - yeah i have a motorcycle breaker, pretty sure that would work . We do have an Ace here (and a Grainger maybe) - thanks !
Old 10-07-2009, 10:54 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Have you thought about contacting one of the forum sponsors?? I'm sure one of us must sell chains...
Old 10-07-2009, 12:47 PM
Deadend's Avatar
Sold, thanks mayne!
Old 10-08-2009, 04:05 PM
mick29 mick29 is offline
Howdy Deadend I went to my local motorbike shop they sell chains that fit thanks mick29
