Old 10-06-2009, 09:04 AM
ride65 ride65 is offline
Default Why do 2 stroke motors run different ratio's of oil in the fuel mix
Some 16:1 40:1 50:1 depending one the motor. what is the reason for some to need a richer mix then others?
Old 10-06-2009, 09:30 AM
bandito bandito is offline
Banned
Default Re: Why do 2 stroke motors run different ratio's of oil in the fuel mix
It seems to me the oil ratio mix is in direct proportion to the owners ego!
Old 10-06-2009, 09:38 AM
donuts31 donuts31 is offline
Ignorance by both manufacturer and owner.
Old 10-06-2009, 09:45 AM
BarelyAWake's Avatar
Well, if yer talking about different brands and type of motors than just our chinagirls - much of the variance in manufacturer's recommendations has to do with that specific engine's machining tolerances, operating RPM range, and application.
If yer askin' bout just our lil bike motors - depends on what the owner is willing to experiment with. The manufacturer's "16:1 & 20:1" recommendations for our bike may in fact include the possibility of using standard (read low-grade) motor oil instead of 2 cycle, but these are sloppy lil motors that may or may not need a lil extra lube... but therein lurks a debate lol
I'm quite happy running 36:1 with Amsoil's synthetic "50:1" but some are of course running the 100:1 stuff at various ratios... it's up to you
Old 10-06-2009, 10:34 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I use regular 2-cycle oil, & break in the engine with 24:1 mix. After the break in, I use 32:1.
Old 10-06-2009, 04:18 PM
Bikeguy Joe's Avatar
Venice got those instructions from me.
Old 10-07-2009, 09:11 AM
xlite xlite is offline
Environmentally conscious individuals will use 50:1 or synthetic 100:1. Others need to leave a trail behind so they won't get lost so use more oil.
FYI more oil in the gas results in a leaner mixture, not richer.
Old 10-07-2009, 09:18 AM
FlyJSH FlyJSH is offline
So what is the correct ratio if I use Crisco?
You gotta be smarter than the tool you use.
Old 10-07-2009, 09:19 AM
1:1
I wanna see pics tho o.o
Old 10-07-2009, 09:20 AM
I believe the OP meant richer as in "oil to gasoline".
But, yes think about it....at 32:1 you have twice as much gasoline running through the jet than you do at 16:1.
In honesty, I run 40:1 any more since all my other "goodies" run that mix.
I have recommended 24:1 in the past because I have had a couple of Big Name sellers ask me to refrain from suggesting anything but 16:1 or 20:1 for warranty reasons, so that is sort of a compromise.
So, for the record, run whatever you are comfortable running, and live with the concequences.
