Old 10-05-2009, 08:14 PM
rdrunner2010 rdrunner2010 is offline
Question Please help with kit!
I know that I shouldn't be posting a new thread without commenting some more, but I really need help with my first kit.. Me and my dad have been putting together the Grubee Skyhawk GT2B kit from King's, and so far we've run into too many problems to count. Most of them have been fixed, and there's only three things left to do: Fix the clutch issue, fix the chain issue, and install the gas tank.
The clutch issue is that we can't see what the clutch arm that the cable attaches to does. We have no idea what the resistance should be and how pulling the clutch arm a tiny distance will do anything since the chain is going to move no matter what if the rear wheel is turning. Can anyone help me understand how the clutch arm works and how to install the cable to it properly?
The other issue is that the chain needs to be tightened one more hole, but we tried it and there isn't a recieving hole for the master link, there's just a pin, and I know why but my question is whether or not I should use the chain tensioner provided in the kit? It seems that it would be loud if the chain was constantly running across the plastic pully. Should I just wrap electrical tape around it and try to dull the sound or is there a better solution?
Thanks in advance for the help, I plan on being an active member of the site now that I have some experience with making a motorized bike.
Old 10-05-2009, 08:39 PM
2door's Avatar
2door 2door is offline
Default Re: Please help with kit!
rdrunner2010,
Welcome to you and your dad. You've come to the right place for help. Let's take them one at a time:
1. Clutch: The clutch arm on the engine by way of a cam pushes in on a steel pin and ball bearing that applies pressure against the spring which puts pressure against the clutch pads, or pucks, as some call them. When the spring is depressed the clutch is what we call, disengaged. It is like pushing the clutch pedal down on a standard transmission car. The sprocket will always rotate when the rear wheel turns but with the clutch disengaged it is disconnected from the engine crankshaft. To properly install the cable you'll want to have just a very little bit of free play in that arm with the cable connected and the handlebar lever un touched, or not squeezed. About 1/8th inch or less of play is good. When you squeeze the lever that arm should move inward, toward the motor about an inch. That should get you in the ball park as far as getting the clutch to work. A little adjustment afterwards might be necessary due to the cable stretching.
Chain: When you shorten a roller chain, that's the proper name for the type of chain we're dealing with, you'll have to remove two links, not just one. There is a male and female end, or as you said, a receiving hole and a pin. To get the master link to work you'll need two holes.
Chain tensioner: The Kit supplied plastic or nylon wheels can be noisy but the engine, clutch and chain will make more noise than the tensioner wheel. The trick to getting the tensioner to work correctly is to bend, or twist the bracket so the centerline of the wheel aligns with the path of the chain. Most kit brackets do not allow the wheel to run in line with the chain and tend to pull the chain to one side or the other without bending or twisting the bracket before final installation. Many of us who have been around the block a few times secure the bracket to the frame with a small bolt and nut through a hole drilled completely through the bracket and bike frame. That will assure the bracket will not loosen and rotate into your rear wheel/spokes, which can be a dangerous and expensive event. If we can be of further assistance please feel free to post your questions. We'll do our best to get you on the road quickly and safely.
Old 10-05-2009, 11:28 PM
george_n_texas george_n_texas is offline
Took me a while to figure out the clutch cable goes thru a hole under the carb mount
Old 10-06-2009, 03:30 AM
bandito bandito is offline
Banned
Theres another site where folks would come on asking for help and right away the 1st 3 responses were why dont you go search that subject has been covered, I could never figure that out. 80%? of the forum seems to be able to help folks fix a problem and if you dont want to help dont.......Im ranting and its 230 am and no coffe yet. RDrunner ask away bro!
Old 10-06-2009, 05:44 AM
Thanks a lot for the responses guys! Later on in the day, around 5:30 ET I might have this up and running, if Murphy's Law doesn't come into play. If it is running, i'll post results. Just on a side note will drilling a hole for the chain tensioner weaken the bar? But I think I will do that, because I read about people breaking their spokes in another thread.
Old 10-06-2009, 06:09 AM
BarelyAWake's Avatar
Welcome fellow Mainiac Good to have ya here!
If yer bike has a steel frame, drilling a hole for locking the chain tensioner isn't a bad way to go, but here are a few other ideas;
http://motorbicycling.com/f11/chain-...ons-11815.html
Old 10-06-2009, 07:50 AM
xlite xlite is offline
IMO if your bike has dropouts that allow moving rear wheel back and forth and sprockets are not way out of line then you don't need a tensioner. The half dozen or so problems I ran into were CAUSED and not solved by having a tensioner. Two guys had to buy new rear wheels.
Old 10-06-2009, 09:42 AM
Banned
Theres alot of weight on those 2 frame stems that go to the back wheel from the crank housing and PERSONALLY I would not drill a hole in them, their not very big to begin with and to weaken one intentionally doesnt seem like a good idea to me. At least 50% of the weight of the bike and the rider goes through those stems plus with the vibration of a happy times your just asking for a disaster.
Old 10-06-2009, 10:29 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
I put two small sheet metel screws into the tensioner & frame to keep it from moving. Never had a problem. Don't use large screws.
Old 10-06-2009, 04:37 PM
Banned
Just my opinion on what I wouldnt do. Theres no doubt in my mind you have way more experience with bicycles then I do. My frame is aluminum and maybe that is what scares me.
