Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories for your motorized bicycle
Old 05-27-2008, 07:08 AM
nitroscope8 nitroscope8 is offline
Default Kill switch and light question
I see some of you have lights rigged up to the 6 volt system. One member I think custom made his own lighting system...not bad. My question is how do you rig a lighting system without stalling the engine? I mean, if that white wire gets grounded, the engine will stall (obviously) and if you put a few ohms of resistance into that kill switch circuit won't it lose spark and stall? Maybe someone can explain it a little better to me.
I feel silly...i'm a Vw tech and I still havent figured this simple system out lol.
Old 05-27-2008, 08:36 AM
sisdavid sisdavid is offline
Default Re: Kill switch and light question
Also, seems like it would be a good idea to take a 6V light system with the generator, and just take the generator off and use the lights, but people sell the complete bike set up with lights with a generator why?
Old 05-27-2008, 08:42 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Norman builds one I have no idea. My system killed the engine when I built it from a lantern,,,
Boy go fast is offering one now His hooks from the white wire and then on to the blue wire no ground at all. I have no idea how it works.
Old 05-27-2008, 09:41 AM
Ilikeabikea's Avatar
Normans white wire lights work off of the white wire only. The kill switch just shorts the blue and black wire together. With the white wire only light you ground to the frame. Norman did lots of R & D to find the correct bulb to make sufficient light that won't kill the engine and won't burn the bulb out the first 3 mins. They work great, he even sells a tail light that will work with it too........................
Old 05-27-2008, 04:55 PM
Wait, how is the kill switch supposed to wire up? I have both of mine rigged grounding the white wire. It shuts the engine off instantly. Been doing that for years lol.
Old 05-27-2008, 06:32 PM
I have my kill switch wired so that it shorts the blue and black wire together. The white wire is to generate a minute amount of power for accessories..........
Old 06-01-2008, 03:07 AM
fuzz fuzz is offline
can the genrator be wired in series with the white wire ?
beer
Old 06-01-2008, 09:11 PM
What does mean in series, I am not an electrical person.
Old 06-01-2008, 11:22 PM
NeutronBomb NeutronBomb is offline
I bought a light on ebay, this one, and unhooked the white wire from the kill switch, hooked it onto the light, started her up and it was on. I wondered why it didnt kill the engine either.. it worked though! I just ran the engine without a kill switch, i mean, really you don't need it.. unfortunately i hooked it up one night and the next day my bike got stolen. it looked rad but wasn't as big as i expected.. hey i sound like my girlfriend!
Orphans don't run from no one!
Old 06-04-2008, 09:17 PM
in line with each other , use both the generator , and the engine for power ( beer
