Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories for your motorized bicycle
Old 10-03-2009, 10:08 PM
Mike Hunt Mike Hunt is offline
Default how can i make this light brighter?
i have one of these Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts except just front light and no generator, powered off two AA batteries. i had it for a while and the light wasn't that bright, and then the mount snapped so i replaced it with a regular bicycle light. i really like the look of this light though, and im willing to make a stronger mount for it if i could get it to shine brighter. i have a SLA 6v 4ah rechargeable battery that i want to use for this. will the bulbs handle 6v? is a 6v light even bright enough for a headlight?
also does anyone have experience with this combined throttle and dual brake lever Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts
is it just me or is the lever made of plastic?
Old 10-03-2009, 10:29 PM
HoughMade's Avatar
HoughMade HoughMade is offline
Default Re: how can i make this light brighter?
Just find a bulb with the same base with the highest wattage for a 6v you can find. A bulb made for 3 volts will not last long with 6. Radio Shack sells numerous bulbs of many voltages- and wattages with the same base. Wattage is more a rough estimate of brightness- volts is not.
I have that thottle- brake handle. It's all aluminum except the handgrip itself.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 10-03-2009, 10:34 PM
sojudave sojudave is offline
6v should work, though I would run a fuse (15-20amp) between the battery and the light. I made a post in the chopshop section of this forum about my light project. I am using 2 6v lantern batteries in series (which makes it a 12v system) to power a pair of fog lights and a trailer taillight on my bike. I prefer to use a 12v system because it gives me more options. A 6v battery can run a 12v light but it will be dimmer.
Locktite. Learn it, Love it, Live it.
Old 10-03-2009, 10:37 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Here's what I did,
Buy High Brightness 3W 80 lm White Lumen LED, 1 pcs - eBay (item 250494697618 end time Oct-06-09 20:27:32 PDT)
3W LED Driver for Luxeon White Green Blue - eBay (item 250388393355 end time Oct-08-09 04:21:36 PDT)
and
15 Degree Lens for Lux LEDs ,5pcs---White - eBay (item 230335027423 end time Oct-29-09 17:52:30 PDT)
Cut the reflector in the headlight so the LED lens fits and glue into place w/ epoxy. Mount the LED to the reflector and wire to the driver circuit, wire the driver to the switch in the headlight and connect headlight to your battery.
I love mine.
Old 10-04-2009, 01:35 AM
how bright is 80 lumens?
Old 10-04-2009, 10:23 AM
Kevlarr's Avatar
Let me put it to you this way, you don't want to look at the light directly and I can light up street signs from a block away.
Old 10-04-2009, 10:30 AM
TheE TheE is offline
Says in the description they use 12V bulbs. 6V shouldn't put a dent in it.
