Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 10-03-2009, 08:21 PM
Fossil's Avatar
Fossil Fossil is offline
Default My heavy duty 4 stroke engine mount.
I made this mount for a Harbor Freight 79cc engine we mounted in a Schwinn Corvette frame but it will work for other engines as well. This mount is not adjustable for length because it was easier to built it to fit the frame. It is over kill because I used 3/16" steel but I wanted it strong. I did two things that make this different from most other mounts. First I made the brackets that attach to the bike frame adjustable to match the angle of the down tube and the seat tube. Second the rear mount longer to allow two mounting u-bolts to help eliminate the sliding of the mount down the seat tube. I hope you guys can use this information. here are the pictures.
Jim
ID:	14039   Click image for larger version
ID:	14040   Click image for larger version
ID:	14041   Click image for larger version
ID:	14042   Click image for larger version
I didn't say it was your fault, I said I was blaming you.
EZ Motorbike Distributor / Dealer Guthriesville Pa
Old 10-03-2009, 09:30 PM
skyl4rk's Avatar
skyl4rk skyl4rk is offline
Default Re: My heavy duty 4 stroke engine mount.
How did you bend it?
Drive fast, take chances.
Old 10-03-2009, 09:40 PM
Fossil's Avatar
I had the guys at the Gap Repair and Steel shop do the bending. Those Amish guys do nice work. I made the mounts out of aluminum flashing material and they used their hydraulic press break to match with steel what I made out of light weight aluminum.
I guess you can say I cheated but I know I could not bend the steel the way I wanted it.
Jim
Old 10-03-2009, 10:28 PM
KilroyCD's Avatar
KilroyCD KilroyCD is offline
Here's a link to the thread about the bike this mount was built for: http://motorbicycling.com/f37/harbor...tml#post113041
EZ Motorbike Dealer - Quarryville, PA
http://ezmoflancaster.blogspot.com/
"That dog is about as subtle as a hand grenade in a barrel of oatmeal..."
-Foghorn Leghorn
Old 10-04-2009, 10:03 AM
skyl4rk's Avatar
Thanks
Do you know what gauge steel they used?
Old 10-04-2009, 10:15 AM
Fossil's Avatar
3/16" cold rolled steel. The base could be made from 1/8" but mounts themselves should be 3/16"
Jim
Old 10-04-2009, 10:55 AM
the willi the willi is offline
Dude very nice work cant wait to see the finish product! that is taking these bikes to the next level! out of the box! remember ride long, live long, later willi
Old 10-04-2009, 02:26 PM
azbill's Avatar
azbill azbill is offline
excellent job on the mounts Jim !
very functional, and without sacrificing looks
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 01-07-2010, 08:58 PM
tyrslider's Avatar
Nice sturdy mount! A sturdy mount makes all the difference in reliabilty w these 4 smokers. Evan FBC
FireBelly Cycles and MachineWorks (lol)
Motorized Bicycles, Parts, Tools and Accessories for the Real World!
Email Support@FireBellyCycles.com
www.FireBellyCycles.com
http://www.youtube.com/watch?v=-kNGVCnjJVs
Old 01-07-2010, 09:56 PM
Fossil's Avatar
Thanks Evan
It took a little tweaking to get it correct but everything about this project is taking some tweaking. When your starting from scratch the whole project becomes a learning process.
Jim
