Old 09-30-2009, 09:57 AM
azbill's Avatar
azbill azbill is offline
Default looking for a stretch frame and how to re-inforce it
I am thinking about converting a stretch frame to use a derailleur
how hard would it be ?
would I have to change the dropouts, or could I just make a hanger for the derailleur ?
I want to add rear v-brake bosses as well
I plan on using a 4cycle with a custom motor mount (EZM, no surprise there )
I also need advice on where to beef up the frame with gussets
does anyone know a cheap place to find a frame ???
I have upgraded components I plan on swapping over from my Jag
just in the dreaming/planning stage right now, but need some tips
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-30-2009, 10:41 AM
Youngbird's Avatar
Youngbird Youngbird is offline
Vendor
Default Re: looking for a stretch frame and how to re-inforce it
Bicycle Designer....$169.00-199.00
Old 10-01-2009, 02:29 AM
azbill's Avatar
been there, seen it...thanks anyways
lots of looks but no other ideas ???
I have found brake bosses and derailleur hangers (both weld-ons)online but am still researching the conversion
I still need advice on beefing up the frame, I plan on making it my daily driver and need it to stay together
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 10-01-2009, 12:27 PM
ocscully ocscully is offline
Here is a frame only from Frame 26" Stretch Limo CP - Choppers U.S., LLC but they indicate that they are temp. out of stock but coming Soon?
ocscully
Old 10-15-2009, 08:16 PM
bandito bandito is offline
I have never stretched a frame, couldt you just cut in 2 places say the top tube and the bottom tube going from the crank hub to the neck and use tubing that would fit right over the existing cut tubes then braze or weld them? Not a butt joint but like a sleeve type fitting. It would seem that would be stronger than the original frame itself as far as the joints are concerned......maybe thats not where you want it stretched?
Old 10-16-2009, 09:46 AM
azbill's Avatar
I have seen azvinnie stretch occ frames that way
I am more interested in a stretch limo style ride (I finally got to ride one a couple of weeks ago)
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 10-16-2009, 08:27 PM
Junster's Avatar
Junster Junster is offline
These kinda what your looking for Bill?
bikebuyers.com
Put something FUN between your legs..
Old 10-16-2009, 08:38 PM
azbill's Avatar
junster, that is the best price I have seen so far
thanks !!!
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 10-17-2009, 02:58 AM
george_n_texas george_n_texas is offline
I was looking at that frame...looks very cool but where you mount the engine...the bottom does not look like you could attatch bottom mount to.
Old 10-17-2009, 10:04 AM
azbill's Avatar
aha...I am going 4cycle...the straight bottom tube will make mounting easy
that's my hope anyhow !!!
Bill
www.ezmotorbike.com
azgrampa@gmail.com
