Old 09-29-2009, 10:30 AM
crzyolphart's Avatar
crzyolphart crzyolphart is offline
Question fuel question
Anybody tried diesel rather than gas/oil mix in their
two strokes? Sure would solve the hassle of mixing!
Just curious if it's too lean.
Rob
Old 09-29-2009, 10:37 AM
freewheeling frank freewheeling frank is offline
Default Re: fuel question
not high enough compression i dont think but if anybody wants to try let me know the results
Old 09-29-2009, 02:50 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I really don't think that will work...
Old 09-29-2009, 02:52 PM
noco noco is offline
hey did you read my mind last night...the compression is definately not high enough...but it would self lubricate....you know...a new head, take away that restricting carb... fix the read valves...it might have enough running compression...but youd still have to start off
Old 09-29-2009, 03:36 PM
bandito bandito is offline
Banned
Bud lite works better!
Old 09-30-2009, 03:42 AM
i agree with bandito....but i would argue for a better beer
Old 09-30-2009, 04:49 AM
Banned
Ever see a diesel with a carb? Diesel wont vapororize like gas does with the venturi effect, thats why diesels have injector pumps and injectors.
Old 09-30-2009, 07:03 AM
To all who replied; This is why I posted that question. You all woke up a slumbering corner of my brain. Higher compression, injectors,
cold start issues, etc. I'm thinking now of changing my moniker to
senileolphart. (that played **** with spell checker;</ ) I should've thought of that, but, apparently I was suffering from "brain fart". Too bad, as; I kind of miss the smell of diesel in the morning.
Old 09-30-2009, 07:43 AM
BarelyAWake's Avatar
Well - I can sure as **** see the attraction! Lower RPM, gobs of torque, and far better fuel efficiency... Seems as if a diesel would be far better suited for this application than the average 2 stroke.
This was a common theme with ultralight aviation too, a diesel is far better for spinnin' a prop than the almost mandatory two stroke for all the above reasons. There were some noises about power/weight ratio but mostly the problem was the same as with our bikes...
They're simply not readily available in this country
While pretty common in Europe (particularly England) we never found a company there that would ship one to us. I haven't looked specifically for a diesel appropriate for our bike's needs - I'm sure they exist somewhere, in the correct size/HP anyway but prolly not set up to bolt in the frame lol
If anyone hears of something that might work - defo gimmie a shout
Old 09-30-2009, 02:20 PM
Banned
With this new low sulphur diesel fuel thats required diesels are alot more friendly to city folks, a diesel motor will out last a gas motor by 3 to 1 in my opinion. Audis and MB have diesels that rock, VW too.
