Old 09-27-2009, 03:47 PM
dirtybird dirtybird is offline
Default help choosing exhaust?
Problem with carb/throttle cleared up. BUT. Isn't that always the word? I bent my stock muffler with a torch to "make it fit", and now the flange is bent. U guessed it- LOUD popping exhaust from the leak. I am going to get a new muffler- BUT- what should I get? I have a "built-in" kickstand on the Schwinn Cruiser 7 , and it is welded in (so i dont know if I can go with the SBP expansion pipe system or simply get a replacement muffler or one of those longer "poo-poo" pipes) Whatcha think everybody? Thanks- Rob
Old 09-28-2009, 02:08 AM
stv1jzgte stv1jzgte is offline
Default Re: help choosing exhaust?
How bent is that flange? could it be file'd flat or grinded just a thought.
steve
Old 09-28-2009, 10:35 AM
It's cupped, and I tried to "correct" it with the aid of a ball-peen, but its pretty out of whack.. I went ahead and bought one of those expansion chamber mufflers over at spooky-tooth ($50). Looks like it will fit perfect, and increase performance a little. We'll see... Thanks.. Rob
Old 09-29-2009, 04:59 AM
noco noco is offline
im currious as to how those exhaust perform...i definately think that they have more style than the sbp
Old 09-29-2009, 10:52 AM
Hey there, I will post the pics and performance results when I get the part this week. Rob
Old 10-13-2009, 10:21 PM
aquarianmonkey's Avatar
aquarianmonkey aquarianmonkey is offline
It would be nice to have some good choices of pipes but it is limited. I bought an expansion pipe for my bike and it took alot of fabrication to fit it on a stretched beach cruiser. I really did'nt notice much diffrence in performance, but it did look cool. It broke after 2 weeks. Now I have a modified stock pipe that works good. I pulled out the baffle cut the sides off and cut the baffle pipe off than stuffed it back in the muffler and welded it in place. It is not very load and gives me good power up the hills. The exit hole is about the same area as the exhaust port. it would be nice if the baffle on stock pipes had bigger exits hole in them. my bike will struggle going up hills with stock baffles and sound too wimpy lol. Happy Motoring!!!!!!
