Originally Posted by noco
ok are you talking about the primary wires or the seconday wire...the secondary(one that goes to the plug)is made of fiberglass...it has a high resistance but the voltage out of your coil pack is high...remember its gotta also jump a spark gap...the primary wires cannot have resistance to them...i don't care if you solder, buttconnect, or twist them together...as long as you have got good contact then this thing will run
Not sure what you meen by primary and secondary wires.
There are 2 wires from the cdi solder them to the wires off the motor thats all
The sparkplug wire (Or cdi wire) does not have fibreglass in it
