Re: need help with assembly of bike: brakes
that's what i had to do.take the coaster brake lever off. put it in a vise, whack it with a hammer out from the sprocket, far enough to miss the bolt heads, then reposition the lever, whack it back in so that you can clamp it back to the frame. i also had to add a spacer to bring my lever out past the sprocket where it connects to the axle. just make sure you get it in the vice far enough , where the axle hole is, so that you don't bend your lever in the axle connection area.
