Old 09-23-2009, 08:36 PM
glenz glenz is offline
Default the cranbrook-revisited
oh, one more thing-the Jet kit i put on-the fuel tank fitting cleared the small upper frame tubes just fine- with a Grubbee kit tho' i had to put an L fitting on to clear. i just put an in-line filter on it cus' the carb has a shut-off on it. the only prob. is when i change the filter i'll have to drain the tank! i put good auto fuel line on it too cuz' it would get a little busy! if the cheap line broke with no shut-off! before the carb!! i'm gonna change something to cure the prob.-any suggestions?
