Old 09-23-2009, 10:45 AM
Prasinos's Avatar
Prasinos Prasinos is offline
Default Smoke
A buddy and i mixed 2 oz of sea foam with about 6 oz of mixed gas and it made a decent amount of smoke. This was pretty badass but we still wanted more. So i pose the question: Does anyone know of some other additive out there that will produce smoke without hurting the engine?
Old 09-23-2009, 11:17 AM
restapukin restapukin is offline
Default Re: Smoke
ask mary-jane if bob hope ever gave her a clue
Old 09-23-2009, 12:01 PM
stv1jzgte stv1jzgte is offline
Default Re: Smoke
is sea foam? foam from the sea?......... googling this sea foam.
Old 09-23-2009, 12:32 PM
Tim_B_172's Avatar
Tim_B_172 Tim_B_172 is offline
Default Re: Smoke
LOL, seafoam is a fuel additive that can be used in pretty much all types of reciprocating engines to clean out carbon and other buildups.
Old 09-23-2009, 12:37 PM
freewheeling frank freewheeling frank is offline
Default Re: Smoke
why do you want smoke?
Old 09-23-2009, 12:56 PM
chrisme chrisme is offline
Default Re: Smoke
I wouldn't constantly use seafoam in any engine. Especially not a 2-stroke. It will wear the bearings out.
Old 09-23-2009, 01:10 PM
Default Re: Smoke
So this Sea foam ( blatant false advertising) is ment to smoke.
Seafoam - Mechanical Database
Old 09-23-2009, 01:42 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
Default Re: Smoke
ATF. automatic transmission fluid. i dunno how much to add to your bike, but a "buddy" of mine poured about a capful into my honda civic carb once, and it was full james bond smokescreen for about 6 blocks.
Old 09-23-2009, 03:09 PM
Tim_B_172's Avatar
Default Re: Smoke
According to the directions on the can you add 2 oz per gallon with a 2 cycle. I added 1 oz to my last tank of gas figuring that the tank is actually slightly larger than 1/2 gallon. It smoked a little more than usual at first, but now I'm not noticing any extra smoke and I'm about 1/2 way through the tank. And no I wouldn't run seafoam constantly, it's not meant to be used all the time. When this tank is done I will have a look through the park plug hole and see if the top of my piston looks any cleaner. I'm kind of skeptical myself, but I have heard from a number of reliable people that this stuff works, so we'll see.
Old 09-23-2009, 03:21 PM
Default Re: Smoke
did he also buy you a new cat converter after that? because he owes one ofter that....
