Old 09-21-2009, 01:49 PM
george_n_texas george_n_texas is offline
Default Fuel tank question
I have a flat container designed for oil changing I can mount under my home made trailer and run a fuel ine up to the engine and even have a primer bulb type pump like you use on a motor boat. Question is wil the engine suck the fuel up from a lower spot or is it like the old model-T that had to be backed up the mountain due to gravity feed. I suspect the later. At leaste I can use it for backup fuel it holds just over 2 gallons.
Old 09-21-2009, 02:35 PM
freewheeling frank freewheeling frank is offline
Default Re: Fuel tank question
no it wont suck up the fuel gravity feed only unless you rigged up a pump and that would have to be regulated some how
Old 09-21-2009, 03:38 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Yea you'd need a 6v fuel pump, if you were able to find one I can't see any reason why the float in the carb couldn't handle it if the pressure wasn't too high.
Or you could use a low flow 12v pump and a battery but why? Just stop every 40 or so miles and pour some more gas in the tank.
Old 09-21-2009, 04:10 PM
you could run a 12v pump on 6v thus reducing flow and pressure, i run 12v bilge pumps on 6v on some small gold mining equipment just for that purpose, works good to help recover very fine gold, frank
Old 09-21-2009, 04:13 PM
Kevlarr's Avatar
Might work on some of the small inline pumps. Would be even better if you could find one that can be serviced, open it up and put a lighter spring on the plunger.
