Old 09-21-2009, 11:52 AM
glenz glenz is offline
Default huffy cranbrook
here is the finished product.
Old 09-21-2009, 01:48 PM
Bikeguy Joe's Avatar
Default Re: huffy cranbrook
Nice Job, watch the frame welds.
Old 09-21-2009, 02:37 PM
freewheeling frank freewheeling frank is offline
the only problem i have with my cranbrook is the engine pulls the axle outa the watchamacallits loosening the chain, i dont run a tensioner
Old 09-22-2009, 10:51 PM
toolow's Avatar
toolow toolow is offline
Tightin the wheel nut more bike looks good samone i got they make good bikes I think
Old 09-23-2009, 09:27 AM
Those whatchamacallits are called dropouts.
I would tighten the nuts just a little more, you don't want that whole works coming loose on you....it holds up half the bike.
Old 09-23-2009, 01:46 PM
ya no matter how hard i tighten it still pulls out am gonna build some adjusters like a motorcycle has,pretty simple to do
Old 09-23-2009, 05:53 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
How straight is your sprocket? I've never had the rear axle move on mine and I have the support for my rear rack between the nuts and the frame.
Old 09-23-2009, 06:50 PM
rmeloy34's Avatar
rmeloy34 rmeloy34 is offline
Looks good,did you have any problem fitting the rear sprockett?
how are the breaks working for you?.....I may get one of these
Its often easier to get forgiveness than permission!!....Rob in CT
The First Harleys had pedals!!
Old 09-23-2009, 07:35 PM
my sprocket is true maybe your rack is helping, i do have this rodded just a bit punched out muffler and rejetted for altitude and for rmeloy the brakes suck but i live in a town without paved streets so the gravel can sneak up on ya much better on pavement, the main drag is paved. but still the brakes leave a lot to be desired at 25+ mph, later frank
Old 09-23-2009, 07:37 PM
yes, the rear sprocket was a little challenge. not too bad tho'-i had to open the hole dia. up with a dremel tool, also,i had to squeeze the rear fender with a wood clamp to clear the chain-not too much sacrifice tho' considering the bike only cost 86.00. i've got a gal that wants me to put a kit on a new 2000.00 custom bike from italy! i strongly advised against it, but she wants to do it! no, i'll do another cranbrook tho'-it looks good,its cheap,and it rides really nice-not bad for a total investment of 230.00! have fun!!! p.s.-i also added a front brake,if you don't i think you'll burn up the little coaster brake shoes real quick!
