Old 09-18-2009, 02:22 PM
Nill Nill is offline
Default kill switch wiring
Hi,
My installation manual says to use the short wire coming from the kill switch as a ground and attach the long one to the wire from the engine. However... both wires are long. One is black and one is yellow... does it matter which one I use as the ground?
Old 09-18-2009, 02:37 PM
bseelbach bseelbach is offline
Default Re: kill switch wiring
It doesn't matter. The switch is simply a momentary switch that is normally open and then closed the circuit to short out/ ground out the motor when you push it.
Old 09-18-2009, 03:23 PM
Junster's Avatar
Junster Junster is offline
I went directly to the motor wiring. One side of the kill switch to white, the other side to the black that also goes to the cdi.
Put something FUN between your legs..
Old 09-18-2009, 07:07 PM
Thanks... all set!
