Old 09-17-2009, 09:54 AM
Hot Wheels's Avatar
Hot Wheels Hot Wheels is offline
Default CNS carb fuel leek.
Hi guys, I have a CNS carb and it leeks gas out of the tube under the bowl, is there anything I can do to fix it.
Old 09-17-2009, 12:05 PM
drhofferber drhofferber is offline
Default Re: CNS carb fuel leek.
yes...buy the gray permatex...the type that repeals gas and oil...take the bowl off and use a tooth pick and carefully putt the sealer around the gasket...dont ge sloppy...also put sealer on the two screwes treads...and put it back togeather...let it se for an hour and it should be fixed...the grey permatex is used for the exhaust and anything were oil and gas is...good luck...Dennis
Old 09-17-2009, 12:12 PM
Hot Wheels's Avatar
Hi Dennis, The Fuel Is Coming Out Of The Small Brass Vent Tube At The Bottom. Can I Put A Hose With A Screw Ih It So It Don't Leak.
Old 09-17-2009, 03:46 PM
samething...you need a little wrench to take off but use the same permatex and put it on the threads and o rind and put it back togeather...good luck Dennis
