Old 09-17-2009, 12:29 AM
MasonMcD MasonMcD is offline
Default Another bogging thread
Howdy.
Recently got a Grubee/Black Stallion 66cc/80cc kit and got it up and running after a couple of days. Fun.
Now a week later, however, the engine is a much softer "pokka pokka pokka pokka" rather than the loud "brap brap brap brap" in the first few rides, no power, doesn't idle, just slowly dies, and dies immediately when I pull the clutch.
I've checked the plug, the fuel lines, I've disassembled and reassembled the carb, checked the seals, float, mixture, idle screw. Put the clip on the second groove.
The clutch is fine, everything seems fine. Maybe the actual engine is flooded? I'm going to try riding with the gas cap off, just to cover all the bases. Nope.
It used to idle. It used to run. It didn't used to die when I disengaged the clutch. What's up all of a sudden?
I know it's getting fuel. I know it's getting a spark (it runs for a while) and the plug is tan.
Ghaaaa!
Old 09-17-2009, 12:39 AM
stv1jzgte stv1jzgte is offline
Default Re: Another bogging thread
Originally Posted by MasonMcD View Post
Howdy.
Ghaaaa!
Start with it running and spray some wd40 around the intaket head and base of the jug if she idles up you got a leak. Check head studs are tight
Old 09-17-2009, 01:27 AM
Junster's Avatar
Junster Junster is offline
I agree with STV most likely it's the headbolts.
Put something FUN between your legs..
Old 09-17-2009, 01:34 AM
Where are the headbolts?
Old 09-17-2009, 01:47 AM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
those two things sticking out of frankenstein's neck...
sorry...
the four nuts on the top of your motor. around your sparkplug. DON'T overtighten them, or crank on them while your motor's hot.
Old 09-17-2009, 07:02 AM
Nah. Those were tight. How do you check if the engine itself is flooded? The float in the carb looks like it's doing its job.
Old 09-17-2009, 07:35 AM
whats ya plug look like?
Old 09-17-2009, 07:51 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Make sure the wires to the CDI & kill switch aren't being pinched & grounding out on the frame or engine.
When you say it "dies immediately when I pull the clutch", makes me think its the wires. (i say this because I had a similar problem)
Also, get rid of the plug in connectors & solder & heat shrink the wires.
Old 09-17-2009, 10:46 AM
Bikeguy Joe's Avatar
Replace the spark plug with a new, quality plug.
Old 11-02-2009, 10:23 PM
zaviii zaviii is offline
Try increasing the idle in areas 3 and 4 see video. Sometimes you may have to adjust your carburetor settings from the weather changes.
YouTube - Motorized Bicycle Carb Tuning pt 2
