Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 09-16-2009, 06:41 PM
chicagoschwinn5 chicagoschwinn5 is offline
Default Atom Brake Sprocket Mounting
Hello and thanks for reading. Has anyone ever mounted a sprocket on a Motorized bicycle with a atom brake rear hub? The hub is large and I am wondering if I am going to have trouble mounting the sprocket. John
Old 09-16-2009, 07:26 PM
wheelbender6's Avatar
Default Re: Atom Brake Sprocket Mounting
It will not be a bolt-on. I have a nice shimano roller brake rear wheel that I didn't use on my motor bike for that reason.
One idea is to use a shift kit, which uses your pedal chain and bicycle gears for propulsion.
Another idea is to rig a belt drive, similar to the whizzers.
Atom hubs are cool, so I hope you find a good solution.
Old 09-16-2009, 09:07 PM
I like your idea if the shift kit. I just you tubed it and it is nice but expensive. Thanks John
Old 09-17-2009, 07:42 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I think Kings sprockets or Jim "manic mechanic" can custom make you one; but you'll probably have to custom make the rag joint.
They are both sponsors here...
