Go Back   Motorized Bicycle: Engine Kit Forum > Electric Bicycles E-Bikes > Motorized Electric Bicycles
Motorized Electric Bicycles The motorized electric bicycle is a quiet and efficient form of transportation for general commuting.
Old 09-16-2009, 09:32 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Am I thinking right or
Before I buy a new sprocket for my ebike I just built I want to be sure I have the right thing in mind.
When i go uphill with the motor my bike will not respond to the throttle at all after a certain point. I am thinking about getting a bigger sprocket to get more torque. Motor and controller and throttle all work and are set up for maximum efficiency. I need to get the most out of my sprocket. I am running a 65 tooth sprocket now. I am considering going with an 80tooth.
So what do you think? Should I go eighty tooth or just live with the bike the way it is.
Old 09-16-2009, 11:33 PM
starrunner starrunner is offline
Default Re: Am I thinking right or
A bigger sprocket of course will add more torque for hills, that is if this is the problem to start with. And if it is, a 15 tooth increase is a huge increase in a sprocket size. It should climb a wall if that's what the problem really is.
Old 09-17-2009, 12:18 PM
deacon's Avatar
Well there are only two ways to go... smaller sprocket more speed and bigger sprocket more torque. I switched over a 16" pusher wheels coaster brake assembly to a 20 inch coaster brake hub. It has a 44tooth wheel. That will give me a chance to check out the smaller faster wheel when and if the rain stops.
I have an eighty on order. If this still shuts down on hills, I will go with the eighty. Yesterday I taught myself how to take apart and put back together the guts of a coaster brake wheel so now I can do most anything I want with them.
