Old 09-15-2009, 07:59 AM
toker_ace's Avatar
Default Handlebar vibration solution!
has anyone came up with a way to help with handlebar vibration? I wonder if you could fill them with water or syrup or something?
Old 09-15-2009, 08:05 AM
camlifter's Avatar
camlifter camlifter is offline
Default Re: Handlebar vibration solution!
i fill all my handlebars and frames with expanding foam, the kind that comes in a can from lowes, it works great.
Old 09-15-2009, 08:06 AM
toker_ace's Avatar
expanding? or non-expanding?
Old 09-15-2009, 08:26 AM
drhofferber drhofferber is offline
try GE clear silicone...Dennis
Old 09-15-2009, 08:42 AM
paul's Avatar
paul paul is offline
Administrator
good idea on the foam. i would say the expanding. nice part with that is the stuff is bassically weightless. i am going to try it. i have used greatstuff for other things and like it. here is what it looks like
Old 09-15-2009, 04:04 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
I just replaced my grips with some like these
Made a world of difference.
Does the foam really work? I wouldn't think that it would do much because the foam doesn't have much mass and you need mass to deaden vibration.
Old 09-15-2009, 09:57 PM
toker_ace's Avatar
The more I think about it I think it would be easier to just get some padded gloves to wear? Like mechanic gloves or something.
Old 09-16-2009, 09:13 PM
Russell's Avatar
Russell Russell is offline
Yes padded gloves will help your hands but, does nothing for mirror, speedo or anything else mounted to the hbars.
Old 09-16-2009, 09:20 PM
Russell's Avatar
That foam is right up there with: duct tape, bailing wire and ty-raps! But not sure if it will help in this situation.
Old 09-16-2009, 09:51 PM
BrettMavriK's Avatar
BrettMavriK BrettMavriK is offline
I just isolate my engines from the frame with rubber.
Why not eliminate the source instead of trying to band-aid a problem?
http://s90.photobucket.com/albums/k2...h_IMG00208.jpg
My Production Bobber Build Up
'BrettMavriK
"Everything Is Possible...If You Can See Beyond The Invisible"
