Old 09-15-2009, 03:32 AM
AaronF's Avatar
AaronF AaronF is offline
Default Sprockets
Hi am wanting to get a 32t sprocket and drill my own mounting holes.Could you recommend a few places that sell the blank sprockets and what size of chain is acceptable with these sprockets?
Weldasprocket Assembly, #40 Chain/1/2 in. Pitch, 32T, Hub Series X - 1181168 | Tractor Supply Company
Would that one work along with a number #40 chain?Thanks!
Old 09-15-2009, 04:15 AM
cyclepro101's Avatar
cyclepro101 cyclepro101 is offline
Default Re: Sprockets
Why do u want to drill your own holes? I just redrilled the std 36 spoke sproket for a 32 spoke wheel. Pretty easy.
Old 09-15-2009, 04:23 AM
AaronF's Avatar
I have a 44t sprocket right now an I'd like to get a 32t or something faster because it is mostly flat here.I'm on a small budget for different upgrade parts so I'm still trying to find a blank sprocket since they can be much cheaper than already made ones..There is a few threads here saying that you can use a #41 chain,could i possibly find a 32t sprocket an chain locally?If not what are some websites you'd recommend
Old 09-15-2009, 12:24 PM
azbill's Avatar
azbill azbill is offline
bmikarts.com sells sprockets cheap...I have done business withem before and got good service
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-15-2009, 12:43 PM
AaronF's Avatar
I called tractor supply and they have a 32t sprocket for use with a #40 chain will this work?Quick answers please!!Thanks
Old 09-15-2009, 01:12 PM
azbill's Avatar
not sure of the 40 chain
you could also try a 1-piece cranks sprocket (I have seen them drilled and mounted
any kiddie bikes laying around or a goodwill type place would have a whole bike cheap
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-15-2009, 04:02 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Not sure if you want to go with a sprocket from TSC, it's going to be made for machinery it'll probably be hardened so drilling will be tough and that sprocket only has a 1" bore.
Old 09-15-2009, 04:38 PM
hiker472's Avatar
hiker472 hiker472 is offline
You could check out King's Sales & Service for that sprocket, but call him because he's slow on the email thing.
I got a 34 tooth from him and I can easily get 43 mph on a flat and down hills, it's "Whoopie!!" I'm really movin' now!
Don't feed the bears....
Old 09-15-2009, 04:54 PM
WayneC WayneC is offline
A #40 sprocket is much wider (thicker) then even #41 chain. If you have 410 or 415, the chain won't go on the teeth of the 40. I used a 40 sprocket one time with 41 chain and had to grind the sprocket down A LOT to the 41 chain to work. Not worth the extra work in my opinion.
WC
Old 09-20-2009, 11:20 PM
I just bought a good quality BMX chain. It works great and heaps lighter
