AaronF
Well I'm back again with another problem lol.Alright so when i start up the engine it will take off at top speed an throttling it does nothing.I've lubed the cable sheath an have tried many different things.Now when i take out the idler screw the throttle will work properly,when the idler screw is in with the slide in correctly cap on and when i twist the throttle it seems the slide will move to the side an not allowing the slide to go back into place on the idler screw,neither clutch or throttle cable is tied up to the bike so that's not the problem nor is binding i have defiantly checked all that..Any help would make me happy I'd appreciate it,Thank You.
