Old 05-23-2008, 12:45 PM
cityevader's Avatar
cityevader cityevader is offline
Default Anybody know chain size?
I've got a powerkings PK-80, and the box with the chain shows DH 083-110L. And within a bunch of chinese is a 50. Is this an actual chain size?
The reason I'm asking is that I saw a bearing-ed sprocket I want to use in place of the chinsy plastic idler wheel. In Northern Tools's go-cart section is a sprocket for a #35 chain that would work great if sized correctly.
Old 05-23-2008, 01:56 PM
paul's Avatar
paul paul is online now
Administrator
Default Re: Anybody know chain size?
the chain is a 415 however a #41 will also work. i am not sure about the size you are asking about
Old 05-23-2008, 04:00 PM
Bikeguy Joe's Avatar
#35 won't work.
Chain, Links and Guards for Go Karts and Mini Bikes
#415 which is also called #42 and #41 will work.
Old 05-23-2008, 06:50 PM
misteright1_99's Avatar
If you have room I got this from Tractor Supply. Post lists part #'s, they are not in catalog or online....
http://motorbicycling.com/f6/spring-....html#post9385
