Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-10-2009, 12:18 AM
flaustin flaustin is offline
Default Gear Ratio
For my next build I want to go the non-kit route. I have a 6 Hp 4 cycle engine available, along with a 12 tooth centrifugal clutch. I want to do the build with a chopped 26 in frame using the 26 inch wheels. From what I can measure the clutch engages at about 2000 rpm. I am about 200 lbs. I have looked through the forum and not found any information that would give me the proper gearing for this configuration. I hope someone out there can provide some insight on what I should use as the reduction ratio. Thaks in advance for your support.
Old 09-17-2009, 08:23 PM
motor_head's Avatar
motor_head motor_head is offline
Default Re: Gear Ratio
prolly about 8:1 that will get you to about 35
or 7:1 for right around 40
to do that much reduction you'll have to run a jack shaft unless you can find a 84-95 tooth sprocket for the axel or get a 10 tooth clutch then get a 70-80 tooth sprocket
