Old 09-09-2009, 07:58 AM
T0lly's Avatar
T0lly T0lly is offline
Default TollyFab MK2 MOD01 - first bike
Great forum here, has helped my first project greatly.
The TollyFab MK2 MOD01
I started with a Grubee Skyhawk 66cc kit. Bike is a Schwinn Skyliner. I had planned to use a Trek 820 but it was too small and needed frame mods to fit. I was skeptical when I ordered the kit, but it has met my expectations. I quickly threw this together a couple days ago and have some tweaking to do. I had to modify the intake and move carb to side to clear the frame. The bike has grip shifts on it, so I couldn't use the twist throttle. I robbed a thumb trottle off a mini atv I had in the shop. The Muffler would not clear the pedals so I cut it off and will relocate. After the first test ride I am hooked, these are a blast. I have a small metal fab shop and look forward to making some custom rides. So here is a sneak peek of my first one, more to follow.
Old 09-09-2009, 07:35 PM
Salty Gator's Avatar
Salty Gator Salty Gator is offline
Default Re: TollyFab MK2 MOD01 - first bike
Excellent build Tolly....you faced the same exact issues I had....having to fabricate a side draft intake.....my pedals hit the muff pipe too.. ( easy fix ...just vice it and bend )......and you're rigtht. these *SCREAM*. LOL. have fun mate !
Laters,
Salty
Old 09-09-2009, 07:46 PM
Nicholas Marker Nicholas Marker is offline
How do you actually bend the muffler? Do you heat it up???
Thanks
Nicholas
Old 09-09-2009, 07:59 PM
Thanks
Nicholas
Not at all....just vice it at it's greatest length...( the pipe not the actual muffler ) and GENTLY push it the direction you need it to go......... don't force it .....take your time.....patience is a virtue
Good luck,
Salty
Old 09-13-2009, 10:01 AM
T0lly's Avatar
Looks like I can post my video link now.
This is the very first test run, just minutes after installing the kit.
YouTube - Motorized bicycle mk2 mod01 01
Old 09-13-2009, 10:22 AM
T0lly's Avatar
Well after the first run I found a list of things I wanted to change. So I tore the bike down and started modding.
I did not like the stock clutch cable setup, it had a bad angle and set the cable against the engine.
I made a bracket that set the cable higher and away from the engine case.
I threw it together quick and already plan another version, but I will run this for a while.
Old 09-13-2009, 10:30 AM
T0lly's Avatar
The stock exhaust did not fit well so that was next on the list. I started by cutting up the exhaust manifold. I noticed the hole ID on the flange did not match the pipe ID. So free performance upgrade just opening up the flange a bit.
Before
After
It is not great but hopefully better.
Old 09-13-2009, 10:31 AM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Great job Like your work!
Only Bikers know why dogs love to stick their heads out of car windows,
Old 09-13-2009, 10:47 AM
The sheer ingenuity of everyone in here never fails to impress me......
Thanks,
Salty
Old 09-13-2009, 11:29 AM
T0lly's Avatar
On the exhaust I cut and rotated the tubing, added and extension, and then added a turnout on the end. This put the muffler along the centerline of the frame tube, away from the pedals. The turnout is to keep the hot gases off the tire.
I am not real happy with how it looks, more function over form.
Do you think I need to add a support for the muffler?
