Old 09-08-2009, 06:07 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Default Heavy duty rims are a PITA!
After the 4th attempt at installing my rear sprocket on a new wheel with 12 gauge spokes I had to give up and walk away for a bit. Got the thing almost perfect on the 1st try on the original rim but this one's gonna drive me insane.
I start out with the hole in the sprocket centered over the hub but every time I start to tighten it seems to walk off center no matter how careful I am. With the thinner spokes I could start tightening with the sprocket already over the shoulder of the hub but with these thicker spokes I have about 1/16" gap.
Tempted to take a belt sander and thin the outside rubber or possibly lube them up a bit so I'm able to move it some before I fully tighten down the bolts.
Any ideas?
Old 09-08-2009, 06:42 PM
HT2005 HT2005 is offline
Default Re: Heavy duty rims are a PITA!
I think I know what you're writing about. I had the problem of the sprocket shifting from center. What I did was wrapped a brake cable around the hub between it and the sprocket. This kept the sprocket from deviating from center. Just wrap it in the gap. After the sprocket was installed and tightened down, I used hot glue to hold the cable in place. I have no sprocket problems due to off center sprocket now.
Old 09-08-2009, 07:28 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
is there room for a flat blade screwdriver or something in the gap?
you could start to snug it, then stick the screwdriver in there and pry it around to where it needs to be.
Old 09-09-2009, 06:25 AM
bseelbach bseelbach is offline
When your sprockets starts to walk, note the high spots using wire method or simply eyeballing it. lay a 2x4 scrap on the sprocket teeth and tap with a hammer. The pine will protect the teeth but allow you to manipulate the sprocket.
Old 09-09-2009, 08:50 AM
"the prussian" Shop Dogs's Avatar
"the prussian" Shop Dogs "the prussian" Shop Dogs is offline
every build we do has this same issue. what weve been doing has worked well.
1st depending on the space involved remove the dust cover and try and find a washer that fits over the hub .
2nd we use an engine lathe but a drill press and file will work to turn down the outside of the washer to fit the id of your sprocket most sprockets seem to have an id of 36.9 mm
a press fit works best but if it slips through take a punch and tap 3or4 spots around the edge to hold the washer in the sprocket during assembly.
3rd tap the washer into the sprocket then use ONLY four bolts at first to align the assembly,tighen only enough to get the rest of the bolts in.
we tighen in a rotating star pattern every other bolt .
as for thining the rubber i have been able to take a razor knife and split the rubber pucks along the "ply" lines but this has never lead to anything very flat .
it seems that wheels from the u.s. and tawain all need this adaptation the two ive built that are from china needed no washer at all? with those we just cut open a beer can and make two long strips of alum then wrap them around the hub and tape into place , however this method takes 5 and a half hands .
if all else fails measure hub and sprocket and post the size and i"ll cut you one and send it out
hope this helps good luck
we few, we happy few, we band of brothers.
for he that shares the road with me shall be my brother. be he nare so vile this ride shall gentile his condition . and pedestrians now afoot will hold there manhood cheap when passed by a motor bike geek
Old 09-09-2009, 12:36 PM
Kevlarr's Avatar
You know, I was thinking about this while walking home for lunch today and I thought that if I only could find some shim material to go around the hub. lol
I think I may have to hone out the sprocket a bit more too. Honed it out to good fit on the original hub but that was black anodized and I have a feeling that even though this hub is by the same manufacturer the chrome is adding a few thousandths that is giving me trouble. The sprocket does fit over the hub but it's a frog's hair off from being a press fit. A few more minutes work with the emery cloth modified brake cylinder hone may just do the trick too.
Old 09-09-2009, 12:50 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Tighten the bolts slowly in a "star" pattern... I use a plastic hammer to tap it into place.
As you're tightening them, stop to make sure it's still straight before tightening them all the way.
Don't use the center hole to make sure it's on straight! Spin the wheel and look at the teeth!!!
Old 09-09-2009, 01:06 PM
Kevlarr's Avatar
Assembling it all on a home-brew truing stand. With just the sprocket pushed onto the hub it's perfectly centered and as straight as an arrow. As soon as I add the rubbers and start tightening the bolts the sprocket walks and ends up catching on the edge of the hub. Ended up having to get new bolts because I started wearing out the threads on the originals. lol
