Old 09-08-2009, 12:20 AM
comradhuff comradhuff is offline
Unhappy Labor Day Disappointment
Hi al,
So I got everything hooked up on my bike with no major problems except for what I would call a mid-size kink in my exhaust. With my wife filming (which may have been my first mistake), I made my first attempt to get the motor running. With no response, I realized that I hadn't opened the fuel valve (call it nerves), but it didn't get any better. I was getting a put-put noise, but it wouldn't fire up. After checking the forums, I tested my spark plug by leaving it exposed (I broke a chunk of one of my cooling fins trying to get the thing out) and riding in the dark. It produced a fairly consistent spark once I got going pretty fast. The spark plug also had traces of gas, so it appears that the gas is getting to it. I also opened up the clutch and tightened the flower nut to the point that if I hold the handle down it won't engage, but using the locking mechanism (which lets out a little slack) is too close and half-engages. So I'm pretty sure the clutch is not the issue. Where those were the two major fixes I saw on the forums I'm pretty stuck now. Someone mentioned that if there are dark splotches on the spark plug then it may mean that I have too much oil in my gas mixture. I think that might be the case, but I'm not sure. I mixed an 8 oz. bottle with 1.012 gallons of gas, so it doesn't seem like that would be the case.
Does anyone know what might be the problem? More importantly, does anyone know how I can fix it?
Thanks,
-Scott
Old 09-08-2009, 01:40 AM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Default Re: Labor Day Disappointment
8 oz. to the gallon works out to 8 to 1. The engines call for 16 to 1 for break in. You have waaaaaay too much oil in your gas.
Get a bigger can and another gallon of gas, take your premix and add it to the fresh gallon and you should be just about right. Oh and make sure to drain the tank and the carb too.
Old 09-08-2009, 08:01 AM
I'm happy to try that if it's going to work, but I want to double check the math. There are 128 oz. in a gallon (8 oz. X 2 oz in a pint X 2 pints in a quart X 4 quarts in a gallon). 128:8 reduces to 16:1. Is this not how it works?
How do you drain the carb? I'm new at this (obviously).
-Scott
Old 09-08-2009, 08:28 AM
Pablo's Avatar
Pablo Pablo is offline
8 oz in one gallon is 16:1
Tell us how your throttle cable bits are hooked up?
Are you getting good compression?
Old 09-08-2009, 12:11 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
check for air leaks at the carb manifold connection that is the number one reason a bike will not start after a new build.
Old 09-08-2009, 01:01 PM
How would I check for leaks and how would I fix them? I thought I might have felt some puffs of air on my left leg as I was going so that sounds like it might be an/the answer.
I think I'm getting good compression. I thought I did the throttle bits as per the instructions. I can give more details when I'm home tonight.
Thanks for the help so far,
-Scott
Old 09-08-2009, 09:20 PM
So I picked up some silicone on my way home today and smeared it on the connection between the carb and the motor. I let it set for an hour, but it didn't make any improvement. I could still feel a puff of air on my leg as it was up in that area though. Is there anything else that might be leaking?
I also disassembled the throttle connection and it seemed to match my instructions. The cylinder moved up when I twisted the throttle handle when I had the carb off. What might possible be wrong that I should check for?
-Scott
Old 09-08-2009, 11:28 PM
2door's Avatar
2door 2door is offline
Okay, you've confirmed that you have spark. At least that's what I gathered from your original post. Now you need fuel and air. Is the choke open, lever down? Are you getting fuel to the carburetor from the tank. Pull the fuel line off the carb and open the petcock (valve) at the tank. You should have fuel flowing. Don't look for a flood of gasoline, just a trickle will be sufficient. Reconnect the fuel line, close the choke maybe half way, depress the fuel primer button on the left side of the carburetor a couple of seconds then start pedaling with the clutch lever pulled in. When you reach 5 to 7 mph release the clutch and tell us what happens next. You should feel the compression of the motor as resistance when you pedal if everything is as its supposed to be and hopefully the motor will start.
Old 09-09-2009, 05:59 PM
Wonder of Wonders:
So I adjusted the choke. My instructions had said to pull it all the way up and the markings on the engine are in chinese so I didn't know any better. I put it all the way down and took it out. When I let the clutch out, it didn't seem to do anything better, but then I used the throttle and it came to life. It was one of the best things to happen to me in recent memory (at least things that don't relate to my son).
Now my problem is that the engine won't idle. It'll stay going while I have the throttle engaged, but it won't keep running when I pull out the clutch. I fiddled with the choke and the idle screw (by no means systematically or extensively) to no avail. I also got the feeling that I should be getting more power than I am, based on what I've read. Is this something dealing with the throttle cable? I'll get to looking on previous posts when I have a chance, but any advice someone could give here would be great.
Everybody's help has been greatly appreciated. If any of you need a Marriage and Family Therapist sometime, I could repay the favor.
-Scott
Old 09-09-2009, 06:56 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
OK now that you have got it to start, once it has warmed up you want to move the choke lever back up. Then your power should increase and then try adjusting the idle screw on the side of the carb. Turn it clockwise to increase idle and counter clockwise to decrease idle.
Design is easy, execution the hard part.
www.sickbikeparts.com
