Old 05-21-2008, 10:20 PM
robo5050 robo5050 is offline
Question Availability of 6mm 9-bolt rag joint sprocket mount parts
Hello forum members,
I was looking online today for replacement parts for the 9 hole,6 mm bolt,
sprocket rag-joint mounts for 36-spoke 26 inch wheels;I have only found the sprocket mounting kit as a complete kit,but no replacement parts for these kits!!
I would like to know if there any online sources for replacement parts-namely ragjoint gasket/9 hole rag-joint clamp-for the 36 spoke mounted sprocket
mounting bracket???
Thanks in advance for any replies!!!
Old 05-22-2008, 07:19 AM
Bikeguy Joe's Avatar
Default Re: Availability of 6mm 9-bolt rag joint sprocket mount parts
Have you contacted the sellers of these bicycle motor kits to see if one would sell you a set?
Old 05-22-2008, 10:57 AM
Smile Re: Availability of 6mm 9-bolt rag joint sprocket mount parts
No,I have not;I will consider that in the near future.
Thanks for the reply!
I am thinking for the money,it probably would be cheaper to order a sprocket mount kit
as a spare since any replacement parts would have to be fabricated!!
Old 05-26-2008, 07:08 PM
Andyinchville1's Avatar
Andyinchville1 Andyinchville1 is offline
Manufacturer/Dealer
Hi Robo,
Is your 6mm mounting kit from Kings (not affiliated with me)?.....Seems that most of the people who have bought sprockets with the smaller bolts have gotten them from them (Kings)...I think Dax sells both setups (6 MM and 8 MM) for something like $14.00...you might want to check him out....He's good to deal with (Duane).
Hope this helps you.
Andrew
