Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-07-2009, 01:33 PM
olgraybeard olgraybeard is offline
Default top cover removeal
stihl 031av I'm trying to strip off as much unneeded stuff from engine, there is a piece of sheetsheet next to the cylinder head between the cylinder head and the top plate either for cooling or stopping heat transfer to top plate. I want to remove the top plate and leave the sheet metal, but I saw on another thread not to remove the plastic fairing (mine's metal) I'm thinking with the sheetmetal next to the cylinder the removal of top plate can't affect cooling. Anyone Know for sure or has anyone done this already.
Old 09-07-2009, 08:06 PM
diceman2004's Avatar
diceman2004 diceman2004 is offline
Default Re: top cover removeal
i have a 4stroke , same kinda deal . the gastank on top of the motor , which i removed also had a tin between the tank and motor . i,m leaving it on , because it directs the air thru the fins . i am going to make a dummy finned head for looks to replace the cooling tin later . but you want to keep your engine as cool as you can . so if it looks like a cooling tin i would leave it on .
Old 09-07-2009, 09:28 PM
don't mind the tin just wanted to get rid of the top cover so it doesn't look like a chain saw. Thanks I thought I knew what I was looking at just wanted to make sure.
