Old 09-07-2009, 06:56 AM
HT2005 HT2005 is offline
Default Ratio Rite mixing cup
Ever since I bought my motorized bike, I 've relied upon guessing the right amount of oil to put into a fuel mixture. Or if I bought the right oil container, I would have used the measured markings on the side of the bottle. After some looking, I found this: Amazon.com: RATIO RITE CUP - Kam-Tech -: Automotive.
The Ratio Rite measuring cup has markings for ratios from 16:1 to 70:1. Markings for 1, 1.5, 2, and 2.5 gallons. Since buying this, I'm sure that I'm mixing the right ratio of oil to gasoline.
Old 09-07-2009, 09:34 AM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
Default Re: Ratio Rite mixing cup
I use beer or soda bottle (12oz) full of oil, & mix it with 3 gallons of gas... A perfect mix every time!!
Old 09-07-2009, 10:26 AM
Humsuckler's Avatar
Humsuckler Humsuckler is offline
ah. i use a syringe combined with an online calculator lol
<code>"isuck@code"</code>
Old 09-07-2009, 10:37 AM
bandito bandito is offline
Banned
For lawn equipment I use to use the premix measured packages of 2 cycle oil and it was for 2 gallons so I always used a 2 gallon can and there was never no guessing, maybe thats not the right ratio for a happy times buy its idiot proof if it is.
Old 09-07-2009, 10:38 AM
Pablo's Avatar
Pablo Pablo is offline
This pup works pretty good, as well easy to keep clean:
Mix Mizer
Old 09-07-2009, 11:28 AM
Mix Mizer
I believe the MixMizer is best for small batches (like for a metal fuel tank on our bikes). What I like about the Ratio Rite cup is that it has a cover to keep dirt out and it has plastic notches indicating ratios for four different batch sizes. The mixing cup is useful for making gallon size batches; this is especially good for making lawn equipment batches quickly for premix containers.
Ratio Rite is good for general use.
Old 09-07-2009, 11:36 AM
Pablo's Avatar
It comes with a cover? Nice. Maybe we should carry that one as well!
Old 09-07-2009, 01:00 PM
city of angels city of angels is offline
i use a shot glass becaus i am using amsoil and i only need 1.5 oz for one gallon of gas i bought at walmart for 1.50 plus tax it works great for me
Old 09-07-2009, 01:45 PM
You should. The ratio increments are as follows:
8:1, 10:1, 12:1, 14:1, 16:1, 20:1, 24:1, 28:1, 32:1, 36:1, 40:1, 44:1, 50:1, 60:1, 70:1
One side of the cup has ratio markings, the other side has standard measurments markings. The measuremens are in pints , cubic centimeters, and fluid ounces.
The only downside is that, due to the fact that the diameter increases from the bottom-up, there is left over residual oil that pools on the bottom of the container after settling. This amount is negligible compared to the amount of oil that is poured.
Old 09-07-2009, 02:14 PM
Mike Hunt Mike Hunt is offline
i got a large glass measuring cup. i use a 40:1 mix, so i fill it with a litre of gasoline and add 25ml of oil then i just pour it in the tank with a funnel
