Old 09-06-2009, 03:25 PM
MarcPhotoMan MarcPhotoMan is offline
Default Cleaning the engine with kerosene
I am cleaning the bottom half of my engine with kerosene as recommend
Is ok to fill the bottom half and let it soak overnight?
Old 09-06-2009, 04:55 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
Default Re: Cleaning the engine with kerosene
Couldn't see why not.
Old 09-06-2009, 06:33 PM
chrisme chrisme is offline
That's what I do to flush out the lower unit of outboards. So I don't see why it would cause any harm. Just a bunch of gears and bearings in the outboard, and just a bunch of bearings in the engine.
Old 09-06-2009, 06:50 PM
GearNut's Avatar
GearNut GearNut is offline
The only risk you chance, as far as I know, is if you left it in for a month or longer. Doing so is not good for the crankshaft seals. Kerosene is a petroleum product yes, yet it also has solvent characteristics. The seals are oil reststant, not necessairly solvent resistant.
FWIW, never clean something with rubber lipped seals installed in it with brake cleaner. That kind of solvent is very detrimental to seals. Carburetor cleaner however is not as harsh to them.
