Old 09-06-2009, 03:56 AM
2 lazy 2 pedal 2 lazy 2 pedal is offline
Default almost ready
my kit 80cc came in friday. installing on a mid 80's BCA. picked it from the trash, lol! cherry mtn bike tho. the chain tensioner stressed me some, wrong angle and not sturdy. I've decided to modify it first thing tomorrow. that an add fuel an I'm off. I hope!! this may be dumb but, I really need to know if there is crank case oil in this thing? I know cars pretty well but not 2 cycle engines. can someone tell me? no plugs, nothing in the manual.. I don't wanna burn it yet..
Old 09-06-2009, 02:41 PM
GearNut's Avatar
GearNut GearNut is offline
Default Re: almost ready
2 strokes burn pre-mix fuel. Oil mixed with the gas. This oil content is what lubricates the bearings in the crankcase. They do not have any other lubrication.
If you are talking about a motorcycle, the gearbox does have gear oil in it. It is in a seprate housing from the engine, contained inside the same engine casting.
Old 09-06-2009, 03:38 PM
BarelyAWake's Avatar
lol ya get points fer asking man, I know far too many people that wouldn't have thought to question such a thing.
Better that then overlooking something that may have been important
Old 09-06-2009, 05:28 PM
thanks guys.
I got about a 20 minute ride and got home just before the rain started, WOW! that was fun! kinda ruff up to about 15mph. then it smoothes out nice. no exhaust smoke. should be lotsa smoke with the 16-1 mix.
Old 09-06-2009, 07:33 PM
GearNut's Avatar
No smoke? What kind of 2 stroke oil are you using, smokeless synthetic, or petroleum?
Old 09-06-2009, 07:53 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
I didn't notice any smoke while I was riding with the Wally World 2 cycle oil I used for break in just a little when I was idling. Just switched to Opti-2 today, ran an entire tank through and now she doesn't smoke at all. Funny thing is I thought I was out of gas WAY before I actually did run out, was so used to seeing blue in the fuel line that when I looked down and saw it was clear I freaked a little because I was 20 miles from home.
Old 09-06-2009, 08:58 PM
I'm using walmart Poulan synthetic oil. I didn't realize it was low smoke. do these motors usually chatter like they're comming apart?
Old 09-06-2009, 10:28 PM
GearNut's Avatar
That depends on what you call chatter.
They do make alot of noise, especially when brand new. The parts need time to bed into each other.
The "break in" period. After that they will quiet down a bit, but still make alot of noises.
Old 09-08-2009, 09:28 AM
I've got just over 40 miles on the bike now. and it runs great under a load accelerating and cruising at about 20 mph. but slowly accelerating or trying to ride slower it runs ruff. should I be trying to tweak the carb yet? or better to get thru breakin first? I don't want to go fast all the time. any advice would be apreciated. THANKS in advance
Old 09-08-2009, 12:11 PM
GearNut's Avatar
It seems like all of the cheap 2 strokes run like carp untill they are finally broken in.
You can fiddle with the carb, but be dam skippy sure it is not running too lean or it will cause horrible damage. Running rich, fuel mixture wise and running rich, oil ratio wise is required for proper break in.
The sparkplug should be black, but not to the point of getting fouled.
