Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 09-05-2009, 11:05 PM
Mike Hunt Mike Hunt is offline
Default fancy nonstock carburators
what is the advantage of getting one of the "performance" carbs to replace the stock carb? i noticed that a lot of people here have them, maybe i should think about getting one as well?
Old 09-05-2009, 11:46 PM
foureasy's Avatar
foureasy foureasy is offline
Default Re: fancy nonstock carburators
because they flow more air. with a bone stock motor under full throttle you will reach a point where the motor will stop accelerating, and you will hear a completely different exhaust note. that is where you ran out of carburetor. a bigger/more efficient carb will keep pulling. you won't lose any fuel efficiency unless you drive it differently. for a stock motor i highly reccomend a dellorto 14/14 SHA if you plan on joining the quest for speed, get the 16/16 SHA. you can use the stock manifold and throttle cable for both, but you will have to try a few different jets. don't misunderstand though, the 16/16 will not make your bike any faster than the 14/14 unless you need the airflow, (portwork). i can give you the jet size for the 16/16 at 2000' altitude with no filter if you like
Old 09-06-2009, 11:39 PM
kirk78400ta kirk78400ta is offline
Any chance you have the port work for 16-16 at 100' above sea level with a filter?
New to this! Suggestions on part sources?
I live in Houston Texas
Thanks!
Old 09-06-2009, 11:54 PM
foureasy's Avatar
port size and port timing depend (in laymans terms) where in the rpm range you want to make power. when you port a motor, you are increasing the amount of air that the motor will need due to the increased rpm range. the only effect that port work will have on a motor, (other than a decrease in life span) will be the requirement of a larger carburetor
Old 09-07-2009, 12:30 AM
what does the "14/14 sha" and the "16/16 sha" refer to? whats the best place to get these?
Old 09-07-2009, 01:27 AM
foureasy's Avatar
SHA : Dellorto Carburetors, And parts for you.
Old 09-07-2009, 05:18 AM
mekano mekano is offline
How about the SHA 15 15? Does it fit, is it suitable?
(I saw it in a store nearby the other day...)
"Burn after reading"
Map yourself: http://zeemaps.com/map?group=178631
Old 09-07-2009, 10:35 AM
foureasy's Avatar
yes, all the sha's will fit. but you will have to mes with the jetting to get it perfect. it will be worth the extra effort.
Old 09-07-2009, 03:11 PM
how does the jet and needle sizing work? how does one find out what the dimensions are when all they specify is "size w6" or "#106"?
Old 09-08-2009, 12:26 AM
foureasy's Avatar
there is no needle on the SHA. just an emulsion tube. what dimensions? you will need some tiny drill bits ( .020-.040") and some solder. it's really not that big of a deal
