Old 09-04-2009, 09:00 AM
Elmo's Avatar
Elmo Elmo is offline
Question Hello from Mississippi
Hi All,
I am 62 and new to motorized bikes. Just found this site yesterday. I have a homebuilt recumbent (toureasy type) and a Homelite weedeater enjine. Trying to figure out how to put them together. I am stuck trying to figure how to fasten a friction roller on the enjine. any ideas? I think I will cut a mounting plate from 3/8" aluminum plate and weld it to a crank arm. I have a bottom bracket in the right place to use as a pivot and will use another crank arm on the other side with an engagement lever to move the roller on and off the tire.
Elmo
Old 09-04-2009, 09:22 AM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Default Re: Hello from Mississippi
Elmo welcome.Where are you in ms.HD
You never know what you might know,you know
Old 09-04-2009, 09:30 AM
Elmo's Avatar
Doc I live close to Natchez. Closer to Washington if you know where that is. Where are you?
Elmo
Old 09-04-2009, 09:40 AM
DOC BOLM's Avatar
In clarksdale.hd
