Old 09-01-2009, 11:26 PM
joewlms3 joewlms3 is offline
Default help! need gas cap ideas
need an idea for homemade gas tank
what to use for a gas filler bung and cap?
Old 09-01-2009, 11:54 PM
GearNut's Avatar
GearNut GearNut is offline
Default Re: help! need gas cap ideas
Any aftermarket Harley shop can order you a weld on bung and a gas cap to fit it.
Also you can check out J&P cycles as well
Here, Aftermarket motorcycle Gas Tanks for your Harley, Metric Cruiser and Sportbike.
Click on "gas tank bung" in the lower left side of the menu.
Old 09-02-2009, 12:02 AM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
What kind of tank are you building? Retro/rat rod? You could always use a cork, it was good enough for Burt Munro.
Old 09-02-2009, 02:11 AM
Junster's Avatar
Junster Junster is offline
If I get around to building a custom tank I'm going to cut the filler neck out of my stock tank to use with the stock cap.
Put something FUN between your legs..
Old 09-02-2009, 11:59 AM
tried welding on the stock filler neck last night
the metal is thin but not so thin it shouldn't be weldable with the machine i have
but it seems to have poor consistency in the steel
messed with it for about 30 minutes then tossed it out
im sure you could oxy-acetylene weld it on no problem
Old 09-04-2009, 10:36 PM
bairdco's Avatar
bairdco bairdco is offline
a guy who makes cool bikes
search "gas bung." there might be a place in your area that sells them on, or check ebay. there's a bunch of different kinds you can weld on.
Old 09-04-2009, 10:51 PM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Junk yard.Get the filler neck from a small car,They are around a foot long and you only need 1 inch of it.You can get a locking cap for it also.HD
You never know what you might know,you know
Old 09-05-2009, 02:22 AM
diceman2004's Avatar
diceman2004 diceman2004 is offline
i always wanted to make a motorcycle tank with a gas tank door , like on a car
Old 09-05-2009, 07:03 AM
RedB66's Avatar
RedB66 RedB66 is offline
Here are some ideas...I've used the flat vented cap from Twisted Choppers
</title> </head> <body bgcolor="black" topmargin="0" bottommargin="0"> <div align="center"> <table width="64" border="0" cellspacing="0" cellpadding="0"> <tr> <td><img src="images/header.jpg" alt="" height="89" width="770" border="0"></td> </tr> <tr>
and these..Gas Caps and Filler Weld Bungs
MOTORBICYCLING.COM STICKERS
