Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 05-21-2008, 11:27 AM
Neko Neko is offline
Default Homelite Super XL 925 Chainsaw
I want to use this engine since it is a 24" bar chainsaw and too much for me to use in the city. and since it is just sitting around I though wouldn't that be great on a bicycle. And here I am posting a thread. Never done this before but am more than willing to give it a go.
thanks for any help that I can get.
Jonas AKA Neko
Old 05-21-2008, 12:23 PM
Ilikeabikea's Avatar
Default Re: Homelite Super XL 925 Chainsaw
You'll probably need a gear reduction. I bet that homelight turns rpm's....................
Old 05-21-2008, 03:51 PM
Bikeguy Joe's Avatar
Mount up a centrifugal clutch with a #41 size sprocket of 9 teeth and mount the engine to the frame. Then install a 48-50T sprocket on the rear wheel, and connect the two with a #41 chain.
That'll get you started.
Old 05-22-2008, 10:23 AM
Thanks for all the help. Guess I would go to thats dax for the parts?
Old 05-22-2008, 02:34 PM
You can buy a rear sprocket kit from any one of several sellers on ebay or with links here on the left.
#41 chain is available at Tractor Supply Co. or similar stores, motorcycle/mower/toy shops.
You will have to brainstorm up a mount for the bicycle motor that will allow a clear shot to the back wheel/sprocket. You'll have to modify the throttle and make sure you have adequate brakes, you'll need them. Don't be afraid to modify/remove/adjust the cover over the clutch on the power unit.
Git buildin'!
Old 07-13-2008, 03:29 PM
Hello and thanks for all the help. I have since bought a chinese motor off ebay other than the clitch handle being really cheap and broke durring install all went well was riding the same day. I go t help for you guy with the kill switch thanks alot. This winter I am going to try and get the chainsaw installed on a bike just got to find the right bike. LOL
Old 07-13-2008, 03:33 PM
Thanks for the update, something we should all try to do more often.
It's always good to know how things went, even if they are going anywhere right now.
Old 08-02-2008, 08:56 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I second the need for updates. I am guilty of going the other way and doing too many progress reports on a project. I really am curious to know what worked when a member has a problem and gets ten different suggestions.
Old 10-18-2009, 01:23 PM
llcoats44 llcoats44 is offline
ok
how do i do that
Old 10-18-2009, 01:26 PM
Thumbs up Re: Homelite Super XL 925 Chainsaw
hello i am Lance Coats out of Chandler AZ
