Old 08-30-2009, 01:31 PM
brine99 brine99 is offline
Default Coaster Brake Sprocket?
Attempting to install sprocket on coaster brake bike. I enlarged hole and removed brake
dust cover, sprocket on but seems teeth very close to spokes. I tested by putting chain on
and chain rubbing against spokes. Seems I need to push out sprocket somehow.
Could I mount it concave side out?
Thanks for help.
Brian in PA
Old 08-30-2009, 01:54 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Coaster Brake Sprocket?
Did you put one of the black donuts between the sprocket & the spokes???
Old 08-30-2009, 02:25 PM
was going to but that step not in the instructions I have. Thanks
Old 01-19-2011, 11:22 AM
heyscuba's Avatar
heyscuba heyscuba is offline
I"m having a problem in this area,...
e-mail me if you can help,...
I'm making the hole bigger now, but fear IF I put that outer washer on the wheel and then the sprocket I will not be able to put the coaster brake bracket into it's slot if supposed to fit into.
heyscuba@charter.net
Old 01-19-2011, 02:46 PM
Goat Herder's Avatar
Gutter Rider
http://motorbicycling.com/f30/coaste...-mod-1841.html
Old 01-19-2011, 07:24 PM
fundreamer1 fundreamer1 is offline
That's the way it seemed to me when I put mine together, but it worked just fine after all.
My first project, but not my last.
http://motorbicycling.com/f40/schwin...ild-25923.html
Old 01-19-2011, 08:22 PM
msrfan msrfan is offline
I like to countersink the sprocket holes and use 1/4 20 X 1 1/2'' flush head bolts from Home Depot. Makes a lot more clearance for the arm without the need for bending it. Just have to make sure you fit the sprocket first and countersink the correct side.
Old 01-19-2011, 08:31 PM
yodar's Avatar
yodar yodar is offline
Originally Posted by Goat Herder View Post
pictures are so helpful (copied to file) for my next build
I did it with a Dremel grind STONE
nOW YOUR ADDITIONAL PICTURES SUGGEST I NEED THE CUTTER DISC TOO!
tHANKS!
yodar
Old 01-20-2011, 08:04 PM
matthurd matthurd is offline
the way i did mine was grind in 1 area just enough to see through the outer ring, then eelled it off with a pair of pliers, came off nice n easy. then i grinded its sides down a bit to make it fit, was a whole lot easier then grinding the entire thing down.
