| Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines. |
08-30-2009, 12:07 PM
Carb spitting oil**Fixed**
Hey, I just put my MB together and got it running, I am running a 20:1 for the break in, The bike starts and idles fine but it will not rev and there is a white foamy oil spitting out of the carb when I hold the throttle open trying to rev it up, I put the clip on the upper slot on the carb to try and lean it out but it does the same thing with no differance at all, I also took the carb apart to see if eveything looked good and I see no problems, no sticking float or loose jet. The exhaust seems clean with no oil dripping out with minimal blue smoke, I'm not sure what to do and any help would be great, Thanks.
Nick
****FIXED IT****
Reason: problem solved
08-30-2009, 12:13 PM
Re: Carb spitting oil
Have you checked the float height?
It could be set too high, letting too much gas into the float bowl.
08-30-2009, 12:30 PM
Yeah, I tried, I bent the little tabs down some and there was no differance at all, thanks
08-30-2009, 12:40 PM
Your carb has rabies???
08-30-2009, 12:42 PM
It sure seems that way
08-30-2009, 12:52 PM
The only other thing I can think of is that the port timing is off between the intake manifold and crankcase (controlled by the piston moving up and down).
In your case, it being a new engine, this seems to be be a factory flaw.
The intake port is letting part of the intake charge flow backwards out the carburetor instead of only going in like it is supposed to. This is quite possible with a 2 stroke engine and one of the reasons why the reed valve assembly came to be.
08-30-2009, 01:17 PM
Have you tried moving the clip down a couple notches to see what happens?
08-30-2009, 04:41 PM
Well its running good now, THE DARN KILL SWITCH, never would of thought that it could cause something like this to happen but when I disconnect it the bike runs great, hook it back up and it won't rev and starts loading up. My guess there must be some kind of resistance in the switch that is causing the engine to misfire, I know it was hooked up the right way, I had the yellow tapped into the blue wire going to the coil and the black wire was grounded to the frame. I just don't get it.
08-30-2009, 05:52 PM
I just replaced the throttle Housing with Integral Kill Switch from Dax for about twelve bucks and it completely changed the way my engine ran. (I think the kill switch was shorting) Its amazing how something small like that can make a huge diffence.
08-30-2009, 08:49 PM
Wow! How on earth could a faulty kill switch cause a carburetor to spit oil?
Very wierd......
| Thread Tools |
| Display Modes |
Linear Mode
