| High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us. |
08-28-2009, 09:27 PM
intake port and intake tube
will this work???
ok if i take off the intake tube from the port and remove the stock gasket..and put ultra grey gasket maker on it, will it improve preformance? i was told it might help..just double checking with people who know what im talking about, i was told the stock gasket covers some of the port??
08-29-2009, 02:00 AM
Re: intake port and intake tube
Originally Posted by Z00mz00m
will this work???
Nah just cut the portion off that covers the port.
08-29-2009, 05:09 AM
I had issues with a reasonably new motor . What your asking did help mine start easier and run better.
08-29-2009, 06:59 AM
Mark the stock gasket and trim it, then smear a thin coat of the sealer on both sides and re-install.
08-29-2009, 01:18 PM
i completely removed the gasket..put a gas &oil resistant gasket maker on it,,,.it seems to help a lilttle bit on starting but not much more power...i did a post on my muffler witch help very much
08-29-2009, 11:13 PM
if that works for you
08-29-2009, 11:20 PM
a couple days after you put it on with silicone, you can take it off and see clearly where either needs to be match ported.
08-30-2009, 12:22 AM
squeeze two pieces of steel together with silicone on it and see where it goes? these surfaces are ment to be used with a GASKET that silicone or gasket maker is doing the same thing as a std gasket does impede flow.
08-30-2009, 04:40 AM
The only impeded flow I have ,is when
I passed 50 years old and nature calls . If you read the directions on the RTV sealer and follow them you will not impede the flow enough to make a differance unless you are in to racing . Excess use of this product isn't a good thing . When you tighten the bolts you have already let the small bead of sealer set for 1 hour to harden. That is how you avoid the oooze factor . As I said before read the directions .
08-30-2009, 05:51 AM
[QUOTE=leftywoody;103143]The only impeded flow I have ,is when
I passed 50 years old and nature calls . If you read the directions on the RTV sealer and follow them you will not impede the flow enough to make a differance unless you are in to racing . Excess use of this product isn't a good thing . When you tighten the bolts you have already let the small bead of sealer set for 1 hour to harden. That is how you avoid the oooze factor . As I said before read the directions .[/QUOT
i use a gasket
| Thread Tools |
| Display Modes |
Linear Mode
